Info faded on info sticker...please help?
Hi, we are having trouble working out what model our air con is, its a Carrier, but the blue sticker with the model number and all other info is faded off. the only legible thing on there is a small number, 32D0021-0, printed on the right hand side at the bottom. is there any other place the number would be located? cos we cant order parts without knowing :(
  • 2,418 Answers
One place to look is in side the control cover, one part of the cover will come off to access the controls. It should have a diagram that may also have these numbers on it. Also the top of the compressor will have numbers that will help a good HVAC parts man find what you need.
Posted on Nov 15, 2009
Please help carrier 38ck03040 outside unit hums but not cooling....top of unit feels hot
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 25, 2011 | Carrier 38CKC042 Air Conditioner
My Carrier Home Central Air Conditioning Model Number 38CKC036 340 fan out side the house is not working it gives oout a low humming sound and fan doesnt rotate Serial Number 4698E05846 Manufacturer...
If the fan is humming and not running them it has gone bad....it will need to be replaced...not all that difficult a job...most pro's do it in less then an hour...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 11, 2010 | Carrier 38CKC036 Air Conditioner
Wiring diagram needed for carrier air con unit
Here ya go:
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/38ckc-c2w.pdf
May 27, 2010 | Carrier 38CKC036 Air Conditioner
Kw for Carrier 42G150H
this is the m# of the air handler take frunt panel off an were the wires go into the unit there sould be another sticker with the kw usally there are 10to 15 kw is an averge house
Mar 15, 2010 | Carrier 38CKC042 Air Conditioner
Carrier air con. expansion valve 5 problems and 5 solutions
1. Mid to late 90's problems on Carrier coils leaking. 2. Problem with lication of TXV's on air handlers. When welded in they were located to close to the fitting where the suction lines were welded in to unit. The heat would cause them to fail.
Feb 21, 2010 | Carrier 38CKC042 Air Conditioner
Hi can someone help with my air con its not blowing cold air but everything else is working fine and the remote even says 16c on it
Hi, Carrier is a well made a/c. If its a window model, and you say all seems to be working good, you need to have someone go outside and see if they can hear the compressor come on when you turn it on. More then likely, its not coming on and you will need a tech to come out and look. You will hear it come on when you lower the temp. It could also be the capacitor. Turn it off for 1/2 an hour, let some body go out and listen when you turn it on. It will be kind of a jolting like humming noise. If it doesn't come on, you will have to have it checked out. I hope this has been of some help. Sincerely, Shastalaker7
PS Please let me no and we can go from there.
Nov 09, 2009 | Carrier BCA101R Air Conditioner
I am looking for specs, specifically the RLA, on a Carrier Model 48LH006600(?)-- not sure about model #, nameplate data is totally faded!
It will tell you on the metal plate on top of the compressor, or sticker what the R.L.A.are and the L.R.A's are. If you cant read them, try and get what information you can from the compressor, like the name, Tecumseh, Copeland scroll, ect, The 48 would be the tonnage, 4 ton, or 60 a 5 ton unit. You should have enough of the model number for a air conditioning wholesale parts house to tell you this. we deal with this in the field daily.
Good Luck, Shastalaker7 I hope this helps you.
Nov 06, 2009 | Humidifiers
Electra remote wont work with electra air con.
hi.you should have a sticker under the indoor unit head unit or on the side.
Jun 10, 2009 | Heating & Cooling
Model number for Carrier furnace with issue for blower 5 minute off delay
I believe that this model number is for an air conditioner evaporator coil. This unit is probably directly attached to your furnace. The Model number for the furnace will be located in the compartment where the flames can be seen. It will be on a sticker or plate that contains lots of other information too like BTU/h, Volts etc...
The number you gave me gives me this info:
Cased air conditioning evaporator coil.
3 Tons
Horizontal application
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
