Question about Kenmore Refrigerators
The ice maker in the door of the freezer half isn't making ice. The ice maker is switched to the 'on' position. Help, please.
  • Hawkster May 11, 2010
    Check water supply and if there is a water filter, check that.
  • 78 Answers
Change filter water
Posted on Nov 15, 2009
Have water no ice
Make sure the ice maker is on, small white rocker switch on ice maker if applicable. Make sure the Wire arm is in the down position. Make sure the water is on.
May 07, 2011 | Maytag MFI2569VE Bottom Freezer French...
Water does not come from the water dispenser and won't make ice and when I checked in the back I saw water halfway in the clear tube that goes into the refrigerator.....
Hi and welcome to FixYa, I am Kelly. Since you did not include your model number I have to respond in GENERIC terms. Open the freezer door and locate the light switch. Depress the light switch to make sure that the light is going off when the freezer door is closed. This light switch (with plunger) also turns off power to the water in door and the ice maker when the door is open. If the light stays on with the switch depressed it will not make ice or pass water through the door. The switch is removed by sliding a putty knife or thin knife blade on on side of the switch to release the locking tab. The switch will have 3 wires on it. C = (common / power) NC = ice maker and NC = light. There will only be continuity between C and either NO or NC depending on the plunger / actuator position. It will never read between all 3 contacts at the same time but C will always be one of the 2 test points. A replacement light / door switch is less than $10.00.
If you want more specific information or need further troubleshooting assistance after checking the door switch, please respond with your model number and I will gladly help you.
Thanks for choosing FixYa,
Kelly
Jan 05, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker is not working
check that the ice maker arm is not in the up position or has come dislogded. if the metal wire is dislodged use a mirror to help put back in the ice maker. put it back in the round white area with an elongated slot. flip down if off. check the ice maker to see if an ice cube got hung up and is jamming it. check with eyes and fingers. last the ice maker will not cycle if the door switch is not activated. this check requires you turn off the ice maker with the arm. come back in 6 hours put the arm back down and hold door switch and see if it starts.
Apr 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker is not making ice.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Subzero ice makers arent all cut and dry. You could have an intermittent issue with either the ice maker itself, or the solenoid valve. SZs also often utilize a door switch which prevents the ice maker from operating if the door or the basket which the ice bucket sits in are not closed or in the proper position. If you have had other what would seem minor problems, that you have lived with, they can inadvertently affect different things. Most sub zero ice makers you can start manually by rotating the ejector comb clockwise as you look at the front of the icemaker, when the icemaker completes its cycle, do you get water to the ice maker, and do you get enough water, usually 140-150 ccs. If the ice maker continues rotating on its own after your initial start up, and receives the proper amount of water, either you have a cooling problem, a door or something is not in the correct closed position, you have a bad switch, or the ice maker is bad. If you receive little or no water at end of cycle, you have a bad valve.
Mar 25, 2010 | Sub-Zero 15.3 cu. ft. / 433 liter Upright...
Whirlpool stopped making ice, water side is fine.
Hi!
Please check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 27, 2009 | Whirlpool ED5SHAXM Side by Side...
Kenmore Ice Maker Not Making Ice
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
May 20, 2009 | Freezers
Ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Apr 12, 2008 | Refrigerators
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
