Question about Sony DVP-CX777ES Multi-disc DVD Player
All discs will not play. Sounds like it is trying to play ...
All discs will not play. Sounds like it is trying to read but after a minute or it goes to the next disc. After all discs are addressed in this manner, it says there are no discs in machine. What may be the problem and how do I solve it? Thanks!
  • 1 more comment
  • darkstar027 Nov 15, 2009
    I tried to contact Julianfix directly but did not see any method to do so on this site.
    Unfortunately
    the issue is not with the optical reader lens. I cleaned the lens and
    then tested it with the cover off. The disc would not spin. I spun
    the disc by hand and it worked. I tried again and it still would not
    spin until I did it manually. I repeated this sequence several times.
    I then let it spin for about 15 minutes. I replaced the cover and
    reconnected the unit to my AV system. The motor hung again. I reached
    in and spun the motor by hand. I then attempted to play the disc and
    it worked. I believe the motor is weak or not getting sufficient
    voltage and that the issue will present itself again. Do you have any
    suggestions other than replacing the motor assembly (not sure what is
    included in the assembly)? If replacement is necessary, do you have
    any suggestions as to where I may find parts? Thank you very much for your time and
    help!
    I hope that I have finally found a way to respond to Julianfix somewhat directly.
    Unfortunately the issue is not with the optical reader lens. I cleaned the lens and then tested it with the cover off. The disc would not spin. I spun the disc by hand and it worked. I tried again and it still would not spin until I did it manually. I repeated this sequence several times. I then let it spin for about 15 minutes. I replaced the cover and reconnected the unit to my AV system. The motor hung again. I reached in and spun the motor by hand. I then attempted to play the disc and it worked. I believe the motor is weak or not getting sufficient voltage and that the issue will present itself again. Note: It has done it again. Can't seem to make it spin now with the cover on it. I am sure I could if I removed the cover and spun the disc while in the play position. Do you have any suggestions other than replacing the motor assembly (not sure what is included in the assembly)? If replacement is necessary, do you have any suggestions as to where I may find parts other than Sony of course? Thank you very much for your time and help!
  • darkstar027 Nov 16, 2009
  • 975 Answers
Try cleaning the OPTICAL lens directly with a Qtip , gently clean it from any debris , and try again , the procedure shouldnt be hard to open it up , good luck ,
thanks AJ
Posted on Nov 15, 2009
I tried playing bully and it will say "reading
if thats the only game it does that for i would clean your disc..it does that when there is a bad disc.
Mar 07, 2011 | Sony PlayStation 2 (PS2) Console
After trying to load disc, message says "cannot play disc" , the machine was previously playing the same disc without issue.
Its time to service ur player. If it reads some discs and some it doesn't read, then switch it off for 10 minutes, let it be on cool mode. Turn it on, try diff discs. If still same, then you may take it to any local tech store for a service.
Jan 17, 2010 | Sony Televison & Video
5 disc cd changer CC4000 will not read
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
Dec 06, 2009 | Marantz CC-4000 5-Disc CD Changer
My DVD player / recorder keeps kicking out the discs I put in. It won't even read them. the screen says close and the tray comes back out almost immediatly. Now it's gotten so bad that the tray won't come...
How old is your DVD recorder/player?
It sounds like it needs a service!
The usual problem with DVD players/recorders not reading discs is that the laser output is starting to fail - and consequently the laser light emitted is insufficient for the system to "read" through the minute "holes" in the disc.
It's possible to have the laser replaced, but this would cost you at least £50, depending on where you live.
Initially, you could try buying (or borrowing) a laser cleaning disc. These cost around £3 to £5 depending on where you buy & live, and have a small brush on the lower side of the disc. Insert this into your player and run the disc for a couple of minutes. If there are any dust particles that have been blocking the light output from your laser head, then this may remove it and might solve the problem.
If this fails, then it seems likely that the laser head is not producing enough output and would have to be replaced with a new one.
Also, you could try playing a CD on your DVD player as these discs contain far less information than a video disc (DVD) and the laser head may be able to cope with this.
If the CD plays ok, then you will know that the reason why it won't play DVD's is the light output has started to fade due to the age or excess use of your system.
Nov 17, 2009 | Sony Televison & Video
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
Won't read disc
sounds like the laser's stuffed. the lasers in those machines are notoriously bad. you'd best be careful. a dodgy laser will cause laser-burn to the discs. i had the same thing on my machine. i could play a couple of games, then there was some that would work after i took them out and put them in, several times. after fixing the laser, ive not had the problem again.
Mar 30, 2009 | Microsoft Xbox 360 Console
My 14" dvd combi player wont read any disc i put in. The only thing that happens is that the main screen says reading disc then about 1 minute later is says please insert a playable disc. I have tried...
The optics can not read the disc. Try cleaning the lens inside using a cotton swab and alcohol. Also try playing a music CD. If the CD plays but a DVD continues to fail, the opticsl will need to be replaced. Depending upon the specific model, this could cost anywhere from $50-$120.
Dan
May 20, 2008 | Philips Televison & Video
Disc unreadable
sounds like dvd rom m8 try it on another console or try anther rom on yours first b4 buying 1
Nov 26, 2007 | Microsoft Xbox 360 Console
DVD stop playing after 20 minutes
Hi Liorpe,
It is possible the Laser is not sliding all the way up and down its rails. Lint , dust, screws sometimes get in the way of the lasers travel to completely read a disc. They do start at the center of the disc and read outward. Sounds like if it will do 20 minutes or so and then quit, its not a heat problem so much as your laser has only 20 minutes of dvd play travel on it rails before it gets stuck. Seen it bunch.
Nov 22, 2007 | Bravo 10.2 IN OVRHEAD LCD W/DVD Car Video...
Sony DVP-CX777ES Multi-disc DVD Player Logo
292 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
