Question about Brother MFC-5840CN All-In-One InkJet Printer
Disassemble I had a nest of ants under the scan glass. Removed 3 screws, but it still doesn't come apart. Scanner doesn't move due to ant debris. Need disassemble directions. Thank You
  • 619 Answers
Hi , If you like i have suggestion , do you have vacuum cleaner having small extension can reach to the nest of ants .
Posted on Jan 12, 2008
How to get rid of sandgroper insect from lawn
Banish Ants with Betel Leaf Betel leaf is often found as a fracture (chewed-chewed) by parents of old. Usually used to keep teeth durable. Apparently the leaves of this one plant is also able to mengtasi ant problem at home. You only need to use a few pieces of kneaded leaves to remove the scent. The aroma is so hated by the ants that they will stay away from the area of betel leaf squeeze. Overcoming Ants with Coffee Powder If we humans generally love coffee then not so with ants. The ants do not like the name of coffee especially in the form of powder. How to repel ants using this coffee powder is quite easy. Just by sprinkling coffee powder on the area we want to avoid touching the ants then they will stay away from it. It can also be sprinkled in the ant's nest so they run away forever. Expelling Ants with Cucumber There are interesting facts that you need to know about ants. Generally these colonized insects are not very happy with the name cucumber. So by placing a cucumber slice on the ant nest will get them going. Can also by putya in the path of the ants passed blinded mice. Dispose of Ants Using Salt How to repel the next ant that is utilizing one of the kitchen ingredients that is salt. Salty salt taste so disturbing ants that they will avoid it. How to use salt to repel ants can be mixed with warm water and sprayed into ant nests or areas that want to be shunned by ants.
Feb 12, 2018 | Cars & Trucks
I have ants in my printer under the glass and need to get them out
What is the brand and model of the printer? Post that with your question. Each printer is different.
Mar 02, 2013 | HP D110a Photosmart Color Inkjet Printer...
Is using termite control around my garden dangerous for my family?
Any use of chemicals poses some level ofrisk, but with the right precautions it doesn't have to be dangerous to yourfamily. Read this article to get more information about Termite/carp/ antkiller products and their risks.
Jul 17, 2012 | Bonide Termite/Carp. Ant Killer Conc. 1...
I need to buy some Termite/Carp ant killer. How much will it cost me?
Thecost really depends on the of the bottle. If you just need it for homeuse, you can get a smaller quantity. This site has many termite/carp ant killerproducts, check it out
I need to clean the under side of the glass.
Cleaning the glass on what we call a "disposable printer" can be interesting. The simple process is to start pulling screws that appear to permit access to the scanner bed. For Lexmarks this generally involves an almost full disassembly of the machine. If you do get it apart be very careful not to let any dust or debris or solvents get near or on the scanner head, this will likely prevent it from properly calibrating and stop the entire machine from running. New all-in-one machines are generally designed so that if one function fails, the entire machine fails. I would say to just purchase a new machine, a repair bill will easily equal that cost and a novice repair job has a good chance of rendering the machine inoperable.
Jun 08, 2010 | Lexmark X5150 All-In-One InkJet Printer
Have nest of ants under glass. Will not scan
Sorry to hear about the Ants. The only solution I can give you, it to take it outside, and spray with CAN Air, until all out. This is where I would start FIRST.
Good luck...........
Jan 02, 2010 | Brother MFC 210C All-In-One InkJet Printer
Scanner glass clean
Cleaning the glass is rather simple. Take the 2 screws under the cover out. Now gently lift the top part of the scanner (some force may be needed). Then the scanner is in 2 parts and the glass can be cleaned inside and outside with a wet wipe glass cleaning pad. Dry the glass with a towel and inspect the glass with a lamp, that no cleanser remains are left. Now install the scanner in reverse order.
Jun 21, 2009 | Epson Perfection V100 Flatbed Scanner
Disassembly of HP ScanJet 4470c.
You remove the panel that holds the control buttons by putting a small flat head screwdriver under the both outside edges (held by two small pins). Be carefull the ribbon cable does not unplug. After removing the two screws that are under the back hindge slots, the whole top pivots up and off of pins at the front. You feed the panel thru the hole left when you removed it. This frees up the top and the glass on both sides can be cleaned. Hold the glass up to a strong light to be sure it is clean before putting everything back in reverse order
Dec 05, 2008 | HP Scanjet 4470c Flatbed Scanner
Hello Mandb,
I also have ants in my PIXMA MP760 multifunction unit, I have just pulled it apart and reassembled it after removing several black broken bits relating to the hinges at the back of the scanner lid. The ants have seemed to have left home (wishful) but I would recomend you take to it with a phillips screwdriver, (carefully) or, if you don't want to do the surgery, take it out in to the sunshine and leave it there for about an hour, no longer.
Give it a bump every 10minutes or so, just to give the ants a help along.
If this dosent help, try coaxing them out with some ant food, but be there in person to stop them returning afta, a feed.
Failing this, take it to the repairman.
Do NOT spray bug spray into it, if the ants die in there, they will decompose, in the process it will corrode any fine copper tracks on the PCBs, it will only be fit for the dump then.
BTW, food colouring seems to be a cheeeep excellent ink replacement :)
Jun 11, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Ants in the Speaker
um, there may be some schematics at boses website. Weird. Sorry, hope you find something soon...
Apr 11, 2007 | Bose Wave Radio
Brother MFC-5840CN All-In-One InkJet Printer Logo
316 people viewed this question
James Cagle
James Cagle
Jim Keysor
