Question about Whirlpool GGW9868K Gas Dryer
The buttons on my GGW9868 Gas Dryer only og on
GGW9868 Gas Dryer. When I push the button I have selected...which is usually the "Normal" button it only go on when it wants too. It is real fussy...I will push the button nothing happens...come back in 20 minutes push it again and it will work...
  • 666 Answers
SOURCE: Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Posted on Mar 13, 2009
SOURCE: Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Posted on Apr 02, 2009
kvhappliance
  • 218 Answers
SOURCE: My GGQ 9800 gas dryer won't start. It was working
Things to check first on a no start dryer.
Check for power at outlet.
Inspect power cord.
When you try to turn it on do you hear anything?
Check the door switch(does it click when pressed in?)
The next item to check and most likely replace on a completely dead dryer with power and a good door switch would be the thermal fuse located inside the cabinet.
Please let me know if I can help with anything else
Posted on Apr 08, 2010
rickead1
  • 1998 Answers
SOURCE: My dryer a Whirlpool. will run for about 10 to 20
there is a hi and a low tempreture sensor best to check those for continuity first when the dryer heats up and gets to hot the hi will turn off the heater where as when the low gets to cool it will turn it back on
hope this helps
Posted on Apr 30, 2010
heatman101
  • 43501 Answers
SOURCE: Whilpool Electric Dryer, WED9200SQ, green
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jul 11, 2010
My Neptune dryer has begun beeping when off. Now the control panel lights are on, power button is blinking and none of the buttons will work
Owner's manual? Troubleshooting section. Customer service call. They are usually helpful. Wild guess, problem with the gas supply. Could be lower than normal gas pressure because of the high demand in cold weather. Could also be a similar electrical voltage lower than normal. The "brains" in appliances are too smart sometimes.
Feb 28, 2015 | Maytag Neptune MDG5500AW Gas Dryer
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
Maytag Gas Dryer has power (light is on), but when I push the Start Button, nothing happens. The Dryer is a Maytag MGD5570, just under 4 years old. I checked the Thermal Fuse with a continuity tester and...
I had the same problem. Here's a quick test you need to do. It will take two individuals (unless you're extremely talented) Open the dryer door and push in the door switch... and hold it in. Have the other person push on (and hold) the start button on the console. At that same time everyone is pushing the switches take a free hand and reach into the dryer and try to spin it. Sometimes just a little push (assistance) is all it takes and..... bingo the dryer starts up! If that's the case... your motor is on its way out or it's gone. Usually due to the bearings on the motor being badly worn.
Feb 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
LG Gas Dryer (dlg0452w) needs a push to get going
heatman101
Apr 19, 2010 | LG DLG0452W Gas Dryer
I have a ggw9868 gas dryer it works fine but it beeps at all times... i use the test diagnostic and casual led constantly flashes and also beeps. when it finish a cycle after a few minutes display goes on...
The display board with the buttons, or user interface has a stuck keypad on it. Sounds like the casual button is the culprit. The dryer thinks you are constantly pushing the key that is stuck and is beeping and starting itself up. I tried looking up the part number for you but it looks like the model should be ggw9868 and then K then L,Q, or T and then a number. You will also need the color for the part lookup. The part is called Panel, Console (includes key switch). This replaces the whole front panel assembly and should take care of your problem.
Please rate this post. Thank You
Jan 21, 2010 | Dryers
No hot air
This advice is for problems associated with GAS DRYERS that RUN, but DO NOT HEAT. Ensure your dryer ducting is clear and not clogged, first. ALL dryers require proper air flow in order to dry efficiently. If you do not have any obvious vent duct obstructions you can follow these simple steps in identifying WHICH dryer heating circuit component may be defective BEFORE you have to disassemble anything. With the dryer plugged in and the gas supply turned on, follow these steps:
PUSH START – Listen for a “click”. You have to listen carefully to hear it. If no “click” is heard when you push the start button, this is usually an indication of a bad RADIANT HEAT SENSOR.
PUSH START – “Clicking” sound is present, but dryer still does not ignite. This is usually an indication of a bad IGNITER.
PUSH START – Dryer ignites, but heating circuits shut off after a short period of time. You attempt to restart, but the dryer makes a “buzzing” sound. This is usually an indication of a bad GAS VALVE SOLENOID.
Now, these initial symptom analyses will give you a rough idea of where to begin troubleshooting. These tips are NOT all inclusive, but suited for the more common problems encountered with dryer ignition problems. In theory the dryer ignition works like this – You push the start button and the igniter begins to glow. This igniter will produce a certain current potential (roughly 2.5 to 3.7 amps, depending on type of igniter) and the gas valve will open. Once the gas valve opens, you have ignition. This is a built in safety feature of the unit that prevents free flowing gas inside your home or garage without ignition. If you suspect a bad gas valve solenoid, the dryer usually has two of them. It is recommended that you replace BOTH of them at the same time. If you suspect the igniter to be bad, open the dryer enough to see the burner assembly. There should be a visible glow from the igniter after you push start. If the igniter does NOT glow, replace it. If the igniter DOES glow, take a current reading to see if it is producing enough current. Here are the two types of igniters are their specifications:
Carborundum – cylindrical in shape (2.5 to 3.0 amps)
Norton – Rectangular in shape (3.2 to 3.7 amps)
I hope this information is helpful.
Mar 10, 2008 | Kenmore 72622 Gas Dryer
Need advice!
Okay...here's what you need to do to check out a gas dryer:
This advice is for problems associated with GAS DRYERS that RUN, but DO NOT HEAT. Ensure your dryer ducting is clear and **t clogged, first. ALL dryers require proper air flow in order to dry efficiently. If you do **t have any obvious vent duct obstructions you can follow these simple steps in identifying WHICH dryer heating circuit component may be defective BEFORE you have to disassemble anything. With the dryer plugged in and the gas supply turned on, follow these steps:
PUSH START – Listen for a “click”. You have to listen carefully to hear it. If ** “click” is heard when you push the start button, this is usually an indication of a bad RADIANT HEAT SENSOR.
PUSH START – “Clicking” sound is present, but dryer still does **t ignite. This is usually an indication of a bad IGNITER.
Now, these initial symptom analyses will give you a rough idea of where to begin troubleshooting. These tips are NOT all inclusive, but suited for the more common problems encountered with dryer ignition problems. In theory the dryer ignition works like this – You push the start button and the igniter begins to glow. This igniter will produce a certain current potential (roughly 2.5 to 3.7 amps, depending on type of igniter) and the gas valve will open. Once the gas valve opens, you have ignition. This is a built in safety feature of the unit that prevents free flowing gas inside your home or garage without ignition. If you suspect a bad gas valve sole**id, the dryer usually has two of them. It is recommended that you replace BOTH of them at the same time. If you suspect the igniter to be bad, open the dryer e**ugh to see the burner assembly. There should be a visible glow from the igniter after you push start. If the igniter does NOT glow, replace it. If the igniter DOES glow, take a current reading to see if it is producing e**ugh current. Here are the two types of igniters are their specifications:
I hope this information is helpful. Post back if you have any questions/concerns.
PS From the initial indications you gave, it sounds like you may have a bad igniter.
Mar 09, 2008 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool GGW9868K Gas Dryer Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
