Question about Refrigerators
Whirlpool refrigerator bulb "blew" with a flash. replaced with bulb (works in other socket outside refrig) not working in refig. is there a reset button
    Problem Solver:
  • 5 Answers
No there isn't. Most likely has blown the door switch, disconnect the power from your power point and join the switch wires together, wrap in electrical tape and try on power. If that's the problem you will need a new switch, otherwise with the power off and disconnected remove the bulb holder and check that for damage.
Posted on Nov 15, 2009
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
Jul 26, 2011 | Whirlpool Refrigerators
Freezer work but refig isn't is there something that regulate the cold air from freezer to refig beside the one in the refrig becuase it't working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 19, 2011 | Maytag Refrigerators
My wife opened the refrig. door and saw a blue flash now all the lights in the refrig side are out and the temp gage indicator lights are out as well.
Blue flash sounds like an electrical short (spark) that blew a fuse or tripped a breaker.
Is the machine running? You need to unplug and check the switch that turns the light on and the lamp socket itself for frayed or broken wires befoe restting breaker or replacing fuse. Once your electrical problem is resolved you can reapply power
Jan 20, 2011 | Whirlpool GS6NBEXR Side by Side...
All the lights in the freezer are working. None of the lights in the refrigerator are working. All the bulbs have been changed. Is there a fuse in the refrigerator that would make the lights go out?
In your model , the refrig section light , gets its' power from the control board . When the lights stop working , so will the light for the temp adjustment display . The control board is located behind the refrig , at the bottom , on the left side , inside a white box . It is held on by 2 screws . The part costs around $ 80.00 , and is easily replaceable .
Nov 24, 2009 | Whirlpool GD5SHAX Side by Side...
Light and temperature indicator on refregirator do no operate. Wife heard a pop when she opened refrig. door.
If the refrig light AND the temp adjustment knob lights , went out , you need to replace the electronic board . Pt # W10135090 . This part is located behind the refrig , at the bottom left , with 2 screws , inside a white box . The board runs about $ 80.00 , and is easily replaceable .
Nov 22, 2009 | Whirlpool GS6SHEXNS Side by Side...
Fridge is not cold
replace the control board, especially if the freezer still works and you blew out some refrigerator light bulbs lately,its very common part# 4334000 appliance parts pros part is located in lower left rear of refrige $81.00cost
Oct 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Light does not work in refrigator, it's not the blub.
Disconnect the refrigerator from AC Power. Remove the light bulb, get a flashlight and look into the socket the bulb screws into and see if there's any corrosion in the socket that could be preventing power from getting to the bulb. If there is corrosion get some steel wool or a scouring pad and thoroughly polish the inside of the socket, (CAUTION BE SURE THE REFRiGERATOR IS NOT PLUGGED INTO THE WALL AC OUTLET WHILE DOING THIS,) After cleaning the socket re-install the bulb and plug refrigerator back into the wall and see if it lights up,when the door is open, if it doesn't, the next thing to check would be the switch that applies power to the bulb when the refrigerator door is opened. It could be stuck or it may have gone bad.
Sep 04, 2009 | Amana Refrigerators
Bulb went uot new bulb not working
...will need to check power at socket. using a multimeter.
Jun 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Water Dispensor Quit Working
if you have water on the floor may be is the line if not water valve
Mar 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
unitsdworking though just no lights in refrig compartment??? if so i would pull unit out nad check laft side bottom of unit for contoil board, remove it and chances are you see a burn mark on one of the circuit, if so youll need to replace it
Feb 18, 2008 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
