Question about Homelite 'Yard Broom' Leaf Blower
Homelite bx90 leaf blower: won't run in cold weather
Homelite bx90: works great in warm weather. won't run more than a minute or so in cold weather???
  • 486 Answers
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 16, 2009
Homelite mighty lite 26bv gas Blower won't run full speed or only in Full Choke
Sounds like a lean condition. Rebuild carb, replace fuel lines and fuel filter and you should be ready to blow the leaves.
Nov 10, 2012 | Homelite Mighty Lite Blowervac
Where is the button to open fuel cap on a chrysler300 year2006
This question needs to be recatagorized... Chrysler does not manufacture leaf blowers.
Jul 17, 2012 | Homelite Gas Fuel Cap Blower Bp250 Bp250i...
I have a Homelite VAC Attack II that dies when you increase the throttle after it has warmed up for about 5 minutes. Any ideas?
Sounds as if its running out of petrol to the carb,have you checked for dirt in the tank,and or carb,failing that,you may need a new carb kit ,diaphram etc,they are available on ebay,rgds
Sep 26, 2010 | Homelite Leaf Vac Attack
I have a homelite yardvark blower and I want to change the fuel filter. How do I change the fuel filter? Yardvark runs fine at beginning, but begins to run eradicatly after a short time. What's the...
could be fuel lines, fuel filter, or your carburetor needs to be rebuilt. The carb has thin rubber diaphragms that get hard over time, hot weather, or stale gas. Need more assistance,
email desertairrepair@aol.com.
Jan 31, 2010 | Homelite 'Yard Broom' Leaf Blower
BX 90 homelite leaf blower two idle screws
The initial setting is 1 1/2 turns out. Screw them all the way in and them turn them 1 1/2 turns out. This is the starting position and should start, it may need some final adjustments to run like you need it to run.
Remember more the screw is out the more fuel it will get.
Good Day.
Oct 14, 2009 | Homelite 'Yard Broom' Leaf Blower
I am trying to start my homelite leaf blower but i dont have the starting instruction sticker that came on it. the sticker had all the steps on how to adjust the two valves, throtle and choke. so if...
Hello ben_brumett:
On My Homelite Blower I Simply Set the Throttle Lock. Pull Out the Choke (on the other I Move a Lever) and Turn on the Switch. Now Pull Until it Starts or Attempts to Start. Remove the Choke and Allow it to Warm Up for 2 or 3 Minutes.
You can Get a Manual from the Following Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information. Remember to have the UT Number if this Unit has One.
Apr 17, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Homelite 'Yard Broom' Leaf Blower Logo
532 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
