Question about Sony KP-57WS510 57" Rear Projection HDTV
Set turns off randomly
When set turns off, the screen goes blue (for awhile, blue was the only color) or red (the current favorite color.) The light blinks an error code of 8 blinks. Sometime the set will work properly if left off for a few minutes, and at other times it keeps shutting off a few seconds after being turned back on.
  • Sony Master
  • 5,138 Answers
There is a capacitor right behind hori output transistor it most of the time goes bad 1200pf 2k volts,yours could be on its way out,when it does set will not come back on.
Posted on Jan 19, 2008
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
On this timer is the light color of time Day and the blue cover on time for night?
You posted under GE 7-day random vacation timer.
This timer shows 7 days of the week.
The nighttime hours are white with blue background.
Daytime hours are blue with white background.
Timer dial rotates clockwise, and make 1 revolution each week.
To set timer, manually rotate dial until current day and hour line up with 'time now' pointer.
Move slide switch to TIMER ON.
Timer randomly turns on-off at preset times.
To watch timer in action: turn lamp ON, plug lamp into timer, plug timer into outlet, and then manually rotate dial clockwise several rotations and watch lamp turn on-off.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
Aug 13, 2011 | GE 50462 7Day Random Vacation Timer
Power is on but after 2-4 seconds display turns off but power is still on where the power light is in blue.it's not in sleep mode where the power color is orange.it just goes back to normal at random...
Without looking at the monitor to confirm this, I suspect you have failing capacitors which power the HT circuit, simply, the power needed to light the display, is leaking to earth, capacitors have lost the ability to store the charge necessary to illuminate the screen, which is why it is working erratically.
You need to get this checked out by a TV technician.
Jul 23, 2011 | Acer Computers & Internet
Tv just turns off while watching it the screen goes blue than turns off
This is one of a group of sets (KP-57ws500) that had bad picture tubes---all of them had this trouble.
The picture tubes are no longer available from Sony--only available on a rebuild basis from another company--very expensive and usually not worth doing---blue is most common tube to show trouble.
The set is shutting down because if the screen goes bright blue---it pulls too much current and the set goes into protective shutdown.
There is one fairly easy thing that you may be able to do-----I have done it before.
What it entails is getting at the Screen/ Focus control block and turning the Blue Screen control down--if it works it may just buy you some time but I have seen several sets where it allowed the set to have some more life.
Usually if the set was working the way this problem begins is you on a blank video input notice a slight blue color in the background with some faint curved lines visable.
If you want to attempt to do the adjustment--let me know and I will tell you how.
I am here to help people----I have seen over 100 of these Sony sets with this problem---replaced tubes in many of them when they were new or under warranty.
SD TECH
Oct 26, 2009 | Sony KP-57WS500 57" Rear Projection...
Wii standby light
To be precise, you can turn this option off from the Wii System settings -> Wii Connect 24 -> standby connection -> off
When this setting is swiched to off, your console shuts down entirely and there is a RED light on the power button. There will be no need to turn off the console pressing the power button.
Jun 10, 2008 | Nintendo Wii Console
When the TV is swith on,the clicking like noise and the red indicator blinks continuesly.
fly-back has a leak im sure with that.try to check the flyback for blue colored current that goes out from it. this causes the noise, if it has then you can use a sealant to seal the leak
Mar 30, 2008 | InFocus SC-MOTGRY-106H MOTORIZED SCREEN
Aadjusting screen colors
They should be adjusted to set voltages. however it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels. Hope this helps.
Feb 01, 2008 | Hitachi 57F500 57" Rear Projection...
Blue screen of death on a tv??
this could be three differnt things
1. the crt itself could be bad
2.the vertical ic on the crt board
3. the focus pack or focus block
Sep 19, 2007 | Sony KP-53V45 53" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
