Question about RCA HD52W59 HDTV Projection Television
Convergence option missing from set up menu rca hd52w59
  • 668 Answers
Usually if something is missing from the main menu or no longer listed in the menu, is because the Main EEPROM has crashed. To get the right replacement, you will need to have the Chassis number, (CTCXXX), at the time of order. You can order it from Encompass Elect. at 1800-638-3328.
I hope this helps
Skyassoc
Posted on Nov 15, 2009
I see a possible fix for missing convergence on a rca hd52w59 by replacing the convergence fuse. I've looked all over and can't find it. If it really has this fuse, where is it??? Thanks
If your looking in the rear of the set on the far left side you will see a large black HV transformer that has a large red wire coming from its top. Thats the flyback transformer look directly to the right of that and you will see three small brown rectangles with FL221, FL231 and FL251 stamped on it. The center one is FL231 if thats blown the set will have a 3D look and the auto convergence feature will no longer be listed under the setup menu.
Dec 18, 2011 | RCA HD52W59 HDTV Projection Television
Convergenc problems w/ RCA HD52W59 HDTV
sorry but u replace the incorec part , the board which control the convergence voltage on and off is the deflection board , now this board is about $100 - 150 , or if u want to fix it , just solder the flyback , just go to radio shack and get a 25watt solder station and solder rosin , also check for bad fuse , this fuse it dont look like the others , this is a 1/2 watt 250 pico fuse , and is next to the flyback , look like small brow squer little box , there is 3 and the one that is bad is the one in the middle , this 3 pico fuses are togethere u cant miss then , good look
Apr 16, 2010 | RCA HD52W59 HDTV Projection Television
I need to know what convergence board I need and part number. TV is RCA Model HD52W59YX36. Symptom is see 3 d like shadows. When I go to do the covergence adjustment from the setup menu....nothing appears...
You dont need a convergence board. The convergence option missing from the setup menu is a easy cheap repair. www.tvrepairworld.com has the kit called ITC222 & 222A convergence option missing repair kit. It also has the CD with instructions along with the three components that repair that problem.
Mar 27, 2010 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Television--the picture 3-d images colots red blue and green, been working great till this after noon any help please
When you presss menu and then select settings is the auto convergence and convergence options still there or have they disappeared/ Let me know and I will assist you with the problem.
Dec 17, 2009 | RCA HD52W59 HDTV Projection Television
The auto convergence setting is not in the setup menu
the ITC222 convergence option missing repair kit under RCA repair kits will fix that issue. The kit contains the parts and detailed instructions. heres where to get the kit.
http://www.tvrepairworld.com/
Aug 02, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59, Convergence is out, not even on set up menu, and also the picture is bowing. how much to fix or just use it for target practice
you can fix it for 24.00. You can get the ITC222 & ITC222A convergence option missing repair kit at the following link which contains the parts and the CD with instructions on how to do the repair.
Jul 14, 2009 | RCA HD52W59 HDTV Projection Television
Where is the convergence on the rca menu screen
its under the settings option. If its missing you will need the RCA ITC222 convergence option missing repair kit available at the following link. The kit has the replacement parts and the CD with instructions on the repair.
Jul 13, 2009 | RCA HD52W59 HDTV Projection Television
Rca 52 in convergence problem, colors not aligning. convergence is no longer an option on the set up menu to attempt to fix. it no longer appears there. how much to fix this or just junk it. it is almost 4...
You can repair it for about 24.00 you can get the repair kit for that issue at the following link. The Kit contains the parts and the cd with instructions on how to do the repair. Its called the ITC222 and ITC222A convergence option missing repair kit. Its under the RCA repair kits Category.
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Fl231 fuse compatibility
yes, thats the replacement fuse for your set. However unless you have replaced the convergence power supply also chances are the fuse will blow again, as the power supply shorting is what causes the convergence to get out of alignment and it will then blow FL231 thereby removing the convergence option from the menu.
Sep 02, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
308 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
