Question about Hamilton Beach BrewStation 47214 Coffee Maker
I have an a32 hb coffee maker --what is the plastic gadget for in the water compartment?when should it be replaced ?
I think that's just a filter. In case grounds end up in the tank, they won't end up in your cup.
Posted on Nov 16, 2009
HB flex brew model 49995R doesn't brew a full cup of coffee
If it is only 3 weeks old, then dig up the receipt and return for an exchange.
Mar 02, 2015 | Coffee Makers & Espresso Machines
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
Hamilton Beach Brewmaster 47374
The problem is the plastic valve on the bottom of the tank. If you remove the 4 screws connecting the black and white parts together it will expose the valve and you will find that at least one of the tabs that secure the valve are cracked off. You can replace the tank for a new one at HB website for 10 bucks or try to repair the valve yourself.
Apr 23, 2012 | Hamilton Beach BrewStation 47224 Coffee...
My mr coffee pot will not stop brewing when I pour a cup of coffee while it is still brewing. My model has the brew/pause feature
There may be grounds stuck in the spring loaded gadget next to the pot's pour spout - Remove all interior parts and rinse under water.
Sep 29, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Filter problems
You put the gadget in just like a k-cup. Lift the handle insert the little plastic screened cup just as if it was a k-cup and off you go.Make sure you have it tightened or you may get grounds/
Jan 13, 2008 | Keurig B50 Coffee Maker
Coffee lukewarm
If this Christmas, it should still be under warranty. Contact HB for return / replacement.
Jan 07, 2008 | Hamilton Beach BrewStation 47224 Coffee...
Water does not get to main compartment
try priming the machine ( find the plastic gizmo that came with the machine for this purprose..can you get water from the steam nozzle?..there is an internal water filter that may become clogged if you aren't keeping the water tank clean.
Dec 14, 2007 | Saeco Vienna SuperAutomatica Coffee...
Broken filter
1-800-851-8900 for HB customer service
Oct 01, 2007 | Hamilton Beach BrewStation 47214 Coffee...
DGB-600 leak from carafe during brewing
My new Burr Grind & Brew grinds away but all I get is hot water?
Apr 14, 2007 | Cuisinart DGB-600 Coffee Maker
Hamilton Beach BrewStation 47214 Coffee Maker Logo
35 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
