Question about Compaq Keyboard
My compaq pasario keyboard stops working ...I reboot it works for a while...next time I go back to it .. it's not working again .. reboot works then stops again
My laptop keyboard 1234&7890-&shift key is not working now what can I do
Posted on Nov 16, 2009
  • 557 Answers
You first need to try and isolate the problem. Try using a USB keyboard. If you plug a USB keyboard into the laptop and it works with out a problem you need a new keypad. If the USB still is problematic than you may need to do a repair install of windows ( this can be done without changing your files or settings) If that doent solve the problem than its a motherboard issue.
Posted on Nov 15, 2009
Need help changing my keyboard
Try rebooting your PC. Hit the power on button in front or top of your PC's case, wait for it to shut down and then turn it back on again using same button.
Apr 12, 2012 | Compaq Keyboard
Hi my keyboard started working erratically a few days ago. it's an A4tech keyboard. and at first while using photoshop the spacebar stops working then I would have to reset it to have it start working...
It sounds like the keyboard is starting to you can try a different keyboard if you have one and it that works your keyboard is bad. If your other keyboard doesn't work to your port were your keyboard is plugged into maybe going bad, let me now if any of this helps.
Aug 02, 2011 | Compaq Keyboard
I have an old Compaq Presario 6420nx (6000) This happened after updating to a XFX 256 graphics AGP card, I installed all drivers and updated bios. After rebooting , no video,mouse or keyboard working. I...
If your computer works fine with an onboard video, it is possible that your motherboard is not getting much power. The agp video card gets power from the motherboard. I suggest using a different power supply.
Jun 01, 2011 | Computers & Internet
My keyboard OFTEN stops working. I have to reboot
Try changing the keyboard, see if that helps. Key boards are fairly cheap. You failed to mention the Operating System. Win xp, home,
Win 7..??? You might also try updating drivers. To do that, go to Start, control panel, device manager, keyboards, right click and then click update driver. Hope this helps.
Jul 11, 2010 | E-Machines eMachines Desktop PC
My keyboard stopped working
What kind of keyboard connector does it have?
If the end of the connector is round with pins (serial connection), just plug the keyboard back in and reboot the computer. With that style of connector, if they get knocked out or come loose while the computer is running, they will not always work again until you reboot.
If the keyboard uses the flat plug (USB) connector, the computer should be able to pick it up again without a reboot when you reconnect it. Also note that if the keyboard is USB and it stops working; if you have any other USB items hooked up as well (IPod, webcam, external drive,etc), check to see if any of those devices are still working either before rebooting your system. Sometimes, another unrelated USB device may crash causing ALL USB devices to fail simultaneously. If this is the case, unplug all USB devices except your keyboard and reboot. If the keyboard works again, reinstall all of your other devices one at a time until you locate the one that crashed all of them (if that was the case).
Hope this helps.
Mar 19, 2010 | Dell Computers & Internet
Compaq Presario CQ60 touchpad problem.
The touchpad on my Compaq Presario CQ60 has stopped responding
Aug 17, 2009 | Compaq Presario CQ60-220US PC Laptop
Stuck on Compaq Screen and keyboard dead
I would take the cover off and reseat the memory, video card, and processor. Make sure your fan(s) are working too, and blow any dust out of it if you see a lot of build up.
Dec 25, 2008 | HP Compaq Presario SR1720NX (EL435AA) PC...
I have an e-machine with windows xp home edition. my keyboard and mouse are compaq usb. all of the sudden the mouse and keyboard stopped working properly. there was a printer added just before the mouse...
Try uninstalling the printer and all of its software, reboot the computer and see if the keyboard and mouse work again. If they do work again the problem is with compatibility issues with the printer. If not then replace them and try again.
Unfortuneately, although rare, some hardware devices are incompatible with eachother, and simply will not work together on the same system.
Aug 02, 2008 | Compaq Computers & Internet
Logitech cordless keyboard 3100 not working
the problem with cordles keyboards is that the transmitter/receiver works via usb and sometimes the driver does not have time to load for the system to start leaving it dissabled, the reason for this is whts called IRQ interupt requests. Some usb ports get left to the back of the queue when requesting that they need to start up, so unfortunately this is a common fault and may be sorted by trying the keyboard in different usb ports and moving any other peripheralls to different ones, although you will have to reinstall all the drivers as you will be using different ports, so install the keyboard first and then it may get an IRQ of 1 which means 'start me first'
Sep 09, 2007 | Logitech Cordless Desktop MX 967300-0120...
Compaq Keyboard Logo
178 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
