Question about Apple iPod nano
What itunes version was used for ipod nano moderl # A1137 2005?
My computer crashed sometime ago and all my programs were deleted. So I went along and dowloaded an iTunes version 6.05.20. Now when i try to open up iTunes i get this message: The file ** cannot be read because it was creasted by a newer version of i Tunes.
  • 317 Answers
The current version is 7.5, that's what you need to download.
Posted on Jan 09, 2008
Remove password ipod
Depending on the model of your ipod it will differ
iPod Classic password
This works on an iPod 5 th gen
Click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
Click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
Right click select rename to open or delete the folder your Ipod should now be open
ipod touch password
Launch the iTunes program on your computer and click "Help" on the main menu.
Scroll down and click "Check for updates."
Close iTunes.
Connect your iPod to the computer using the supplied USB cable.
Launch iTunes, which will display your iPod on the left panel.
Right-click your iPod in the iTunes program and click "Eject."
Close iTunes and detach your player from the computer to unlock it.
ipod iphone ipad password reset
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Jul 25, 2013 | Apple iPod Audio Players & Recorders
Ipod nano
Please do try changing the USB access option from ur nano / ipod
When the access type is 'MSC', the files will be directly accessible to ur PC as a separate drive
Go to settings/Setup -> USB
(I've encountered similar problems with sansa, and this solves it)
This way, u can delete and add files as u wish
take care
Did I solve ur problem?
Feb 25, 2008 | Apple iPod nano
How do I delete duplicate songs on my Nano 4gb Ipod? How do I adjust the volume?
Using iTunes' "Show Duplicate Items" feature, you can locate and manually remove duplicate songs on your iTunes music library. Once the library is cleaned, you need only sync iTunes with your iPod to remove duplicates from your device as well. This guide takes iTunes 12 to remove song duplicates.
  1. In iTunes, click "View > Show Duplicate Items" in Music module;
  2. Compare the listed song duplicates upon artist, album, date added, genre, play count, size, bit rate, and more to determine which item to keep and which item to remove;
  3. Hold the "Ctrl" key and click each duplicate you wish to delete.
  4. Connect your iPhone 6 to PC, click your iPhone from the device list, hit "Music" and select "Sync" to sync your library using your existing sync settings.
By doing this, you could delete duplicate songs on iPod from your iTunes. But it will eat a lot time of you. To save your time, let's come to the 2nd method - using 3rd-party iTunes cleaner program.
Oct 25, 2010 | Apple iPod nano
I have a 5th generation iPod Nano. I've had it less than one year, and now whenever I plug it into my computer with the USB cord that came with it, my computer says "USB device not recognized" and that the...
  • Check system requirements. - iPod nano (5th generation) requires the following minimum versions of Windows: either Windows XP (Service Pack 3 or later), Vista or Windows 7. If you have one of these versions of Windows, verify that Windows is fully up to date by downloading and installing software updates from Microsoft. If you have Windows XP with Windows XP Service Pack 1 or Windows XP Service Pack 2, download and install Service Pack 3 using Windows Update.
  • iTunes online? - Confirm that iTunes has been downloaded and installed.
  • AMDS online? - iPod nano requires Apple Mobile Device Support (AMDS), which should be automatically installed with iTunes. To verify whether it is installed, click Start > Control Panel. Open the Add or Remove Programs control panel and verify that Apple Mobile Device Support is visible in the list of currently installed programs. If it is not, remove and reinstall iTunes.
  • Check USB connection. - Disconnect all USB devices from the system with the exception of the iPod nano and any USB keyboard and mouse. Then restart your computer. Verify that you are using a high-powered USB 2.0 port. Test with an alternate iPod USB cable if one is available.
  • AMDS - Re-verify that AMDS is running and installed.
  • iTunes usage - Remove and reinstall iTunes.
hope this helps
Oct 14, 2010 | Audio Players & Recorders
My computer crashed. I dowloaded itunes to new one but it won't let me sync the songs I didn't purchase from itunes on my nano.
iTunes will let you transfer your purchased songs from your iPod to your new iTunes as detailed here
For the rest of your iPod music, you will need to use a program like TouchCopy to copy your iPod content onto your computer or straight to your new iTunes. TouchCopy lets you copy all your music, video, photos, contacts, notes, calendars, games and more from your iPod.
To copy your iPod music using TouchCopy, you will need to...
1. Download and install TouchCopy on your computer. TouchCopy works with all iPod types and the iPhone. There are free PC and Mac downloads available from here
2. Ensure that iTunes is closed before connecting your iPod. Then start TouchCopy and connect your iPod. TouchCopy will have fixed your iTunes preferences so that iTunes will not sync music or video with your iPod while TouchCopy is running. These changes are restored when you quit TouchCopy.
3. Use TouchCopy to copy all your iPod content to your computer hard drive or straight into iTunes.
4. You can then use iTunes to re-sync your iPod, which will re-load your iPod with all your music and let you add new content to it too.
Mar 27, 2010 | Apple iPod nano
Please someone Help me with my NANO..I think I deleted...
OK first plug/connect ipod to computer.go to my computer click on ipod icon and format.After format download itunes and install it to the itunes and it will see ipod and load the drivers.More questions or confused,just contact me.Have a great day and if this helped please vote thanks.RICHARDM69 PS YOUR NOT STUPID WE ALL MAKE MISTAKES
Jan 21, 2009 | Apple iPod nano
Cannot eject
The battery shouldn't take that long. Can you see if you have the newest firmware for your iPod? Sometimes when Apple releases a newer version of iTunes a firmware has to be applied to work with older iPods.
Click on the iPod icon in ITunes and check the settings tab in the larger window pan. Click the button Check for update.
You could always shutdown your computer and then disconnect the iPod. If the screen still says do not disconnect when the computer is off, hold down the play center buttons, untill it restarts.
Jul 23, 2008 | Apple iPod nano 3rd Generation
Ipod 1st generation doesnt show up on itunes & wont restore
Do the 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
May 12, 2008 | Apple iPod nano
Lost registration CD
you can get the iTunes program from apples website
Basicly you simply need the itunes, and then your music, witch is on your ipod and your itunes account? so I think you simple have to install itunes, login, plug the ipod in and everything should work as before. Might be a bit difrent if the itunes program has been updated from your previous version.
I think you can order a new cd from apple if you need one.
Apr 08, 2008 | Apple iPod nano
Black iPod Nano 8 GB - NOT detected at all!
if you are running the vista os then there isn't much to say but to keep up on all the updates posted.. vista and itunes crashes a lot amongst other issues it is having.. as for the other's, apple doesn't like to make very user friendly software for window's user's unfortunately so it's glitchy at times so it's very important to keep your stuff backed up at all times.. if there is a new version of itunes, make sure you update it too.. double check that you are not running 2 music programs at once bc sometimes that confuses the pc's as well.. are you running on a duo core or regular processor? sometimes you need to sign out of itunes then back in again.. it's just a very unstable program and many people struggle with it.. i hope you get it figured out.. d
Feb 04, 2008 | Apple iPod nano
Apple iPod nano Logo
103 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
