Question about Dryers
The dryer doesnt have any heat.. how do I replace the heating element?
  • 986 Answers
1) Unplug the dryer and pull it far enough away from the wall to remove the vent hose.
2) Remove the screws securing the rear access panel, leaving the top center screw for last. Set the panel aside.
3) Remove the two wires connected to the limit thermostat on the side of the chimney. You need to write down & remember that the wires go to the thermostat and the spade connectors on the ends of the wires will only fit the thermostat. Remove the two wires at the bottom of the chimney connected to the terminals mounted in ceramic insulators. These terminals are part of the heater element.
4) Now go up to the top of the dryer and remove the two screws under the lint filter (pull the filter out first).
5) We need to open the top of the dryer now. Slide a putty knife in between the dryer top and the cabinet to release the clips holding the top down. Push in and pry up about 2.5" in from each corner (see the diagram below).
6) Grab a stub flat blade screwdriver or a short screwdriver (you aren't going to have much room), raise the top (use your head to prop it up) and remove the sheet metal screw securing the mounting ******** top of the heater chimney (it's way to the back and to your left). Before you remove the strap note how it is looped through the slot on top of the chimney.
6A) Some newer elements are now 1/2 of the size of the older style versions, picture help and more picture help and even more pictuthe dryer doesnt have any heat.. how do I replace - ldrwp-heater-top-clip.jpgldrwp-heater-top-clip.jpg
7) Go back to the rear of the machine and pull the top of the chimney back and out of the drum bulkhead. Note how the chimney sits on two mounting brackets for later reinstallation. Lift the chimney up and off of its mounting brackets.
8) Lay the chimney down with the vent on the top facing you. Remove the sheet metal screw near the bottom. This releases the heater element. Slide the old element othe dryer doesnt have any heat.. how do I replace - ldrwp-broken-element.jpgfailed by locating the break in the coil.
9) Position the chimney above the mounting brackets and carefully lower it into the slots. Push the top of the chimney back into the hole in the drum bulkhead. If the chimney doesn't fit snugly into the hole, check the alignment of the slots at the base of the chimney with those in the mounting brackets.
10) Raise the top again and replace the mounting strap and the screw at the top of the chimney. Lower the top and lock the clips by pushing the top down. Replace the two screws that were under the lint filter. Slide the lint filter back in.
11) Reconnect the two wires to the limit thermostat and the two wires to the heater element terminals. If the heater element terminals are different from those on the ends of the wires that you disconnected, use the connectors supplied with the new element and splice them onto your wires.
12) Replace the rear access panel and its mounting screws. Reconnect the dryer vent hose and plug in the power cord. Check for proper operation.
Posted on Nov 15, 2009
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
Dryer doesnt heat
Its your heating element most likley . could be heat sensor high or low . I would replace the element .
Jan 29, 2012 | Kenmore Dryers
I have a Cabrio dryer from whirlpool model # wgd6200swo and it will not heat up
Your dryers heating element has most likely gone bad. This typically doesnt occur unless the dryer has some age on it but it can happen. The heating element can be accessed from the back of the unit and is quite easly replaced if you are somewhat handy. SAFETY FIRST! Please make sure that you unplug the unit prior to attempting any repairs. Once you have disconnected the unit from its power source, you can begin to replace the heating element. You can usually purchase these elements at your local appliance store. Good luck.
Feb 08, 2011 | Whirlpool Dryers
Doesnt heat thermostat was replaced and fuse replaced still doesnt heat
What is the model number of the dryer? I did not see where you checked the "heating element" on the dryer. Check the element for continuity.
Dec 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My dryer doesnt heat at all! Goes straight to
If your dryer doesn't heat, check these:---- Power from the house:------ Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.----- Heating element:------- Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.---- Thermal fuse:----- On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)---- Wiring:------ A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.-----
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Feb 19, 2010 | LG DLE5977 Electric Dryer
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
Kenmore dryer doesnt heat
You may also need to change your thermal fuse and the thermostat. On some models the thermal fuse operates the heating element only and others the whole dryer
Mar 19, 2009 | Dryers
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Dryer
hi Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
Step 1: Remove the back of the dryer. If necessary, also remove the cabinet top.
Step 2: Disconnect the leads and remove the screws that hold the duct in position. Then lift the entire heater unit out of the dryer.Step 3: Remove the screws that hold the heating element in the duct.
Step 4: Slip the new heating element into the heating duct the same way the old one came out. Be careful not to damage the resistance coils. Replace the screws that hold the heating element in the duct, reconnect the leads, and screw the unit back into position.
now see whether it is ok..............
Sep 12, 2008 | Dryers
Dryer turns on doesnt dry
Suspect heating element or thermal fuse. The heating element and fuse can be checked with an ohm meter. The reading should be 0-2 ohms on both devices. If heating element reads infinity (nothing) replace heating element and fuse. If the fuse reads infinity then replace the fuse.
Jan 06, 2008 | Maytag Performa PAV2200
Dryers Logo
62 people viewed this question
Top Dryers Experts
