Question about Archos TV+ DTV Receiver / Video Recorder
Archos tv+ has constant red blinking light. Froze
Archos tv+ has constant red blinking light. Froze up after firmware upgrade to 2.1. Tried all manual recommended solutions. Won't turn on at all.
I know this was a while ago, but just in case you never fixed it, or someone else needs help with the same problem, here's a possible solution. I had this same problem recently, but didn't realise it was thanks to Archos's latest firmware being dodgy. I actually took the hard drive out at one point, put it in my PC and backed up all the contents. In fact, you simply press the TV button on the remote when the red light is blinking quickly. That takes you to a recovery menu, where you can attempt to repair or format the drive. If you hook it up a PC via USB, you should also be able to access everything on it to back it up.
Anyway, the repair and format options will tell you to connect your device to a PC, but that's just to load a firmware file onto the hard drive. You can just as easily put this file on a USB pen drive, though, and load it from there. You can get firmware files from http://www.archos.com/support/support_tech/updates.html?country=gb&lang=en&#firm. The latest one is there, but ignore that and install the previous version. Hopefully, that should get the TV+ booting again. It worked for me, anyway.
Posted on Mar 01, 2010
Why does it have six red blinking lights?
Hi Tim
In my opinion
No... the LED's are doing their job
Error reporting
Modern TV's are computers and try to indicate where a problem exists.
Does it need a Firmware upgrade?
Red green or orange lights are on or blinking on the TV
Sep 22, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
Archos 704
Did you try power cycling the unit?
Feb 05, 2008 | Archos 704 WiFi Digital Media Player
Archos 5 not working, will not switch on.
Hi I would think the best place to start is with ARCHOS,
give them the lowdown and see what they come up with.
You could use the Archos forum and look through the help files
Apr 13, 2010 | Archos 5 MP3 Player
Power Light Blinks, can't communicate with Linksys Network Adapte
Seems to be a common issue among these routers. If you tried to upgrade the firmware via wireless connection then it will generally fail. It is recommended to upgrade through the wired connection. In most cases if the upgrade failed and will not reset, most likely the firmware on the router has been damaged. Your best bet is to purchase a new router.
Mar 14, 2009 | Linksys Wireless-G WRT54G Router
37' philps flat tv
4 blink error for that model is i2c communication failure specific to ssb (small signal board) if intermittent should upgrade firmware to newest firmware and if constant would need to replace small signal board
Aug 18, 2008 | Philips 42PF9630A 42 in. Plasma Television
No Picture/No Sound
hello,
the 4 blink error I was assuming was a constant vs intermittent issue which is specific to ssb but based off the new information sounds like there was still an issue with the ssb as the firmware upgrade is specific also to ssb as microprocessor and eeprom are located on that board which stores that information. there is good probablility that the firmware was becoming corrupted with the intermittent issue and after the firmware upgrade must have become further corrupted and disabled the video and audio processing done on that board. it was logical to do the firmware upgrade though and no way to know that doing the upgrade would disable the set. hope this helps dan
Aug 15, 2008 | Televison & Video
Archor tv plus 250G
Have you tried the reset button, if that dosent work unplug it and try resetting again
Apr 26, 2008 | Archos TV Plus, 80GB 80 GB Hard Drive
Archos TV+  DTV Receiver / Video Recorder Logo
1,287 people viewed this question
Top Archos Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
JonSnell Electronic
JonSnell Electronic
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
