Question about Sanyo Vpc-s1070w Digital Camera
My memory card wont work in the carmar it says the card is lokked
  • 350 Answers
There is a little slide switch on the edge of the card. Slide it in the opposite direction and be careful when inserting it in the camera or a card reader because sometimes the switch can be moved from hitting the side of the slot and re-lock it on you without your knowledge.
I hope this helps and good luck!
Posted on Nov 15, 2009
  • 561 Answers
On some memory card types there is a lock to stop data being removed form it by accident.
I assume you have an SD type card.
remove the card and look at it with the gold connector at the top and facing you. if you look carefully to the right of the card you will see a notch just below the last connector on the right edge of the card, with a tab in it it is often gray.
Use a finger nail and slide this tab forward towards the top of the card, it is now unlocked and ready for use.
if this is correct and still does not work then there maybe a problem with the card sensor in your camera.
When memory card is inserted the camera wont work
You can insert CF memory and some memory stick cards when you use a special adapter. When you use a memory tick, make sure it is compatible, because the memory stick is the most incompatible memory card, if you have not the correct one.
When you use a CF memory card, check all contacts. Not one contuse pinn in the camera should be belt a little. Use a bright light and a loupe to check.
Feb 13, 2014 | Sony Alpha DSLR-A350 Digital Camera
I cant send music files to it via bluetooth it keeps telling me to delete memory and now ive deleted everything and it still wont let me send music files via bluetooth. I have a nokia navigator 6110
make sure that all of the files that you have sent before via bleutooth was move on your memory card.take a lokk at your phone memory on how much is the free space.because once you transfer file via bluetooth it uses your phone memory. check your inbox outbox and myfolders.delete or move the files that is in there.then try to send via bluetooth again.hope I explained it well.
Apr 15, 2010 | Nokia 6110 Navigator Cell Phone
My sandisk wont read my memory card how do i get
my sandcsk wont read my memory card how do i get it to work
Nov 11, 2009 | SanDisk Sansa e250 MP3 Player
Crupt memory card formet
I had the same problem. Only solution was to get a new one. Usually gets corrupt when it gets wet, broke, or fried in some way. I took mine to the actual company and they lokked and looked and looked for solution i ended just havin to get a new one. Pretty cheap though. 15 mayne 20$ at the most.
Oct 29, 2009 | Nokia N72 Cellular Phone
Wont take pictures
If every thing is working on the cam but the camera, and your cam has a built in memory, take the memory card out. Try using cam with just built in memory. Sometimes the cam wont format right with the memory card. Don't know why, but it just happens. If this works, you'll have to get another memory card. If the cam doesn't read the memory card, it will still work, but it won't take pictures.
Aug 30, 2009 | Bushnell Trail Scout 11-9500c Digital...
Cant open or format 4gb kingston flash
Right click on My Computer, choose Manage
A Computer Management console will appear.
On the left lokk for Disk Management and click on it.
Wait a little until the values on the right loads.
Now locate the Kingston drive, right click it and format it.
Don;t forget to rate this answer if it helps
Jul 20, 2009 | Electronics - Others
Have a sony cyber shot carmar want to load to computer where dose the card go?
If Your Computer Has A Drive For It It Would Be In The Front By The C.d Drive And Floppy Disk. If There isn't A Slot You Need The Cable To Go From Your Easyshare To Your Usb port.
Mar 11, 2009 | Kodak EasyShare LS753 Digital Camera
Wont access memory card
i) try to put memory card in any mobile if it working in it is fine, if not your memory is having some password put on it or attached, try to remove the password and then work with it ........
you can remove password by keeping the memory card only in that mobile where you kept the password(only in that mobile through which u kept the password...)
Dec 28, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
Bluetooth
Back up first files on your memory card on your computer. then format the memory card on the pc. Then put back the formatted memory card and format it again on the phone. Take out your memory card then put it back again on your pc to copy your previous files. This should work.
Memory cards need also formatting same as HDD's
Hope this helps...
Jul 24, 2008 | Nokia 6131 Cellular Phone
Memory card wont work anymore, lost all songs and photos
u have chang ur memori card ic if u r a tecnision then u may urself
Feb 19, 2008 | LG Prada KE850 Cellular Phone
Sanyo Vpc-s1070w Digital Camera Logo
62 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
