Question about Maytag PYE2300AY Electric Dryer
My dryer is squeaking intermittently while drying.
My dryer is squeaking loudly and intermittently while drying.
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Nov 15, 2009
The dryer squeaks... loudly! Is it more likely the glide, the felt, or something else?
Good Morning John,
I understand that the dryer on your Frigidaire laundry center, model# FEX831CS, is squeaking intermittently. I also see that you are wondering if it could be the glide, the felt, or possibly something else, that is causing this. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine the exact cause of the squeaking. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FEX831CS Top Load Stacked...
My dryer GE Electric dryer model DBSR453EBOWW squeaks !!
It could be the drum bearing.You prob need to re-grease it.but it could be a devil to get at.
Jun 22, 2012 | GE DBSR453EBWW Electric Dryer
Dryer drum has an intermittent squeak when running
there is a belt tension'er it might need to be replacing or temp fix greasing or drum bearing replacing or temp fix greasing to do this you will have to remove the drum
May 28, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My dryer has developed a loud squeak when it is drying. Some times it is quiet but other times it is very loud. How what is causing this issue?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 30, 2010 | Fisher and Paykel DE09 Dryer
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
Maytag Neptune Dryer makes loud noise while drying.
heatman101
ergfgfjk
Sep 06, 2009 | LG DLE2514 Electric Dryer
Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Aug 11, 2009 | GE DBSR453EBWW Electric Dryer
Dryer squeekes on and off
Hello.
Intermittent squeaking usually arises from drum rollers, a bearing at the back of the tub or the pulley for the belt. Locate where the squeak is coming from the loudest and you can narrow down the cause.
Loud in the back middle: Drum bearing kit
Loud in the back bottom: Drum rollers.
Loud in the top front: Drum glides
Lound in the bottom front: Belt pulley.
Jul 21, 2009 | Dryers
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
147 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
