Spins fine when on small load but on large load spinning is slower washer is 4yrs old
  • 975 Answers
NEEDS A BRAND NEW MAIN BELT , thanks AJ
Posted on Nov 15, 2009
Will not spin, started getting slower now does not spin out, noted small amount of gear type oil under washer
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The washer quits spinning sometimes, mostly when
May have a basket drive going bad. Not a bad job but can be tedious to get to.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
My 5 year old LSQ9659LW washer pumps but no spin
You could have two problems here. One is a bad timer not giving the signal to spin and the other burning smell is usually a belt slipping on the drive shaft. Either way, it's time to have it checked out. If it it's a newer model without any belt the electric motor is heating up and this definetly needs to be checked out.
Sep 17, 2009 | Washing Machines
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
Final Spin
could be a clogged water pump. check the filter/pump for dirt and small items, socks, pins, coins,
tnx 4 using fixya,
drcool
Oct 11, 2008 | GE WBSE3120B Top Load Washer
Does not always spin
How old and is it on all loads? How fast to stop the machine when you lift the lid? Can you stop the tub while spinning, careful on this one?
Oct 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag atlantis washer
Start by checking the belt by tilting the machine back and examining for wear, glazing and cracks, next pull the belt to make sure everything turns. Post back if this looks fine.
Jul 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Jan 13, 2008 | Frigidaire FTF530FS Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
