Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
I have a dj mixer 600 and the effects went out do you know what could be the problem?
  • 682 Answers
1-try to reset it first-(power off -power on).
2-apply a spray contact cleaner in effect(volume or button)and move it on and off many times (or forward and backward)-you can get the cleaner from radio shack near your home.
3-if all above did not work send it to a repair center.
Posted on Nov 27, 2009
Denon x600 want go to mac
Wrong... there are setting on the mixer that will get u on track..make sure you un plug usb FROM mixer. Turn off I'm not 100% sure ether master effect insert I know it is 1 of the insert buttons wit the right 1 hold down button turn the knob closet effect screen if right that screen should turn from PC 2 MAC when you see this hit the left BEAT BUTTON to save setting
Aug 31, 2012 | Denon DN-X600 DJ MIXER
How can i open the music file for my digital dj pro mixer
I don't know what you are trying to do. But your mixers needs analog inputs such as cd players or turntables.
Feb 12, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
My effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
The right side on my pioneer DJM 600 (effects do not work)
Hiya,
If you are confident with opening up the mixer, do so, and check the ribbon cable which goes from the effects switch board to the main PCB in the middle of the unit. Check it is secure and hasn't come loose with movement or vibration. If it is all secure, and still not working, you will need to send it for repair to your local service centre / tech friend :)
Cheers
Feb 01, 2009 | Pioneer DJM-600 Silver Professional DJ...
Hi,wken i switch on my panasonic mixer grinder ,fire is coming it looks ike something is burning inside .Could u please let me know what happened?
What is a Panasonic Mixer Grinder?
What model?
If there is fire, and it smells like burning, DO NOT DO ANYTHING BUT POWER OFF and UNPLUG THE UNIT. You'll need professional help at this point. Something is obviously burnt inside.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Oct 01, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJM-600 black Professional DJ power on but not working!! i check bouth the fuses and are working i can see that is power in te mixer but no answer with any signal of leds or music signal
So you get power to the unit, but no sound coming out? How about through the headphones, do you get sound coming out of the headphones?
Are all the volumes and gains raised up? All the eq's are up? Check the back of the mixer, there is a master gain volume - where the connections are - make sure this is up also.
If nothing, then you'll need professional help at this point.
- OPTiC
A DJ Pro Audio Co.
Sep 23, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 800. (dj mixer) when turning the master gain volume it doesnt turn the volume up or down unless you put pressure onto it.
apply some spray (lubricant contact cleaner)from radio shack-----to master gain volume and move it up and down many times.
Sep 09, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pionner efx 500
send out from mixer---------to pioneer in---------from pioneer out-----to return in mixer.
May 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
Outputting high pitched sounds and master balance switch problem
Maybe the issue is not with your mixer. Maybe its with one of the units you connect to the mixer. Does this happen in all the channels?
If the service company could not duplicate the problem, then the problem might be somewhere else. Double check and replace your cables going to your amp, as well as the cables coming from your CD players and such.
- OPTiC
A DJ Pro Audio Co.
Dec 06, 2007 | Pioneer DJM-600 Silver Professional DJ...
173 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
