Question about Singer 2732 Mechanical Sewing Machine
How to put singer 2732 bobbin case? Please need
How to put singer 2732 bobbin case back in? Please need help!
  • 3 Answers
SOURCE: bobbin case is popping out, and machine is birdnesting
Usually when this happens the bobbin is in wrong, replace it make sure the thread is going out the right way, make sure there is no lint or small pieces of thread around or underneath the bobbin area. Make sure you thread it with the foot up. Also make sure you are usng the right bobbin for the machine. They can easy get mxed up.
Posted on Jun 20, 2009
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
SOURCE: I have a singer 2732
Hi, I hope this helps. It's kind of hard without pictures, but I'll do my best:
1)With the spool of thread affixed in it's normal spot, take the thread and wind it through that weird hooky thing (like normal) at the 'back' of the machine.
2)Then bring the thread towards the front of the machine and around the metal 'button' on the top of the machine. Do not loop around this, merely guide the thread on on the side closest to you, towards the right hand side of the machine.
3)Thread your bobbin.
4)Put the bobbin on the metal arm and push to the right (gently).
5)Push the 'button' in the hand wheel in so one end of it will pop out (this will stop the needle from going up & down while you're winding the bobbin)
6)Start pressing the foot pedal slowly and things should start to work.
Posted on Jan 11, 2009
  • 4 Answers
SOURCE: Replaced Singer 5932 bobbin case, need help. *pics*
there may be uneeded friction occuring. are you sure you inserted it correctly? sorry. photos aren;t appearing. but it may be that it is the wrong type or in the wrong place. do some trial and error and fit it into different positions on the bobbin runner
Posted on May 11, 2009
My singer 2732 sewing machine will not pick up bobbin thread
There are three causes. Make sure your needle is all the way up in the needle clamp, and the flat side it on the back (if your bobbin is in the front of the needle).
If it is, then your timing is out of synch, and you will need to get a technician to fix it.
Jul 26, 2014 | Singer 2732 Mechanical Sewing Machine
My bobbin on my Singer 4562 keeps bunching up the threads, can you help?
If you have the black bobbin case you must make sure you use only a good mercerised thread, there should be enough gap between the edge of the bobbin case and the silver adjuster to allow the thread to pass through, if there is not then you must slacken off the two screws and move it over a fraction.
Aug 11, 2011 | Singer 2732 Mechanical Sewing Machine
How do you thread the machine and bobbin on this singer model 2732
Sewing machines. All the manufactures copyright their manual. They know that you need a picture. It'll cost ya $12.
:o).
Jun 04, 2011 | Singer 2732 Mechanical Sewing Machine
How to wind the bobbin in a singer model 2732
Go to singerco.com and download a manual for free. It will tell you how to wind the bobbin
Sep 12, 2010 | Singer 2732 Mechanical Sewing Machine
Bobbin winder came apart
they are not an expensive item i sugest buying a new one and save a lot of time and get back to your sewing quicker
Jul 17, 2009 | Singer 2732 Mechanical Sewing Machine
I HAVE A SINGER SEWING MACHINE MODEL 2732 AND NEED TO KNOW HOW TO MAKE THE BOBBIN COME UP. I AM LOOKING FOR THE MANUAL FOR THIS MODEL. PLEASE HELP.
When threading your needle make sure you pull enough thread through...a good 4 inches will do..hold the end of the thread and turn your hand wheel by hand until needle comes back up...you should have a loop around your upper thread ...pull this loop out towards you..you should now have two threads..cut threads till about 2 inches and make sure you position threads through the center of your sewing foot and towards the back of your machine. Good Luck
Jun 13, 2009 | Singer 2732 Mechanical Sewing Machine
Problems with Singer 2732
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jan 02, 2009 | Singer 2732 Mechanical Sewing Machine
I have a singer 2732 and have misplaced the manual. I'm trying to wind thread on a new bobbin but I must have forgot some part of the process. Can anyone offer instructions? Thanks!
Jul 29, 2008 | Singer 2732 Mechanical Sewing Machine
Singer model 2732
It is either inserted incorrectly or the bobbin case needs replacing. Check the bobbin case by running finger tip around the outside of case, if rough spot needs replace. There is a ltch that is spring loaded you must hold back with small bladed screwdriver while inserting case for proper placement
Oct 25, 2007 | Singer 2732 Mechanical Sewing Machine
Singer 2732 Mechanical Sewing Machine Logo
293 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
