Question about Maytag Neptune FAV6800AW Top Load Washer
My maytag topload washing machine leaks out water from the bottom.what could be the cause of this?
    President:
  • 3,085 Answers
More than likely the pump housing is leaking. very common problem.
Posted on Nov 15, 2009
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
Leaking water Maytag Washer
If the connecting hoses is not a problem then it is probably be the pump present inside the machine.It helps in moving and draining the water.If it is not working then such problems might arise.It is best that you ask the plumber to replace it instead of you doing it
yourself.
Apr 10, 2010 | Maytag PAV2300 Top Load Washer
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
How can we troubleshhot a Maytag toploader that
You probably have something stuck in the drain pump. You will have to remove the hoses from the pump to extract it.
I can not be more help without a model number. Maytag builds several styles of top load washers. They all access differently.
Aug 30, 2009 | Maytag Washing Machines
Leaking from the bottom of maytag washing machine
a good possibility that the front door seal is leaking check for tears or any small holes if it is that it it is hard to do
Jun 07, 2009 | Maytag Neptune MAH6500A Front Load Washer
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
I have a maytag 6800 toploader. Water from bottom
If you feel OK to troubleshoot the Service Manual will give you some possible leak points to check. If you want to troubleshoot you beyond basic inspection you will need to remove the front panel and observe where the leak source might be. Worse case a tub seal issue. Easier fix would be a leak in the drain line; tub to drain pump/drain pump to output drain hose, one poster recently reported a cracked drain pump housing as their leak source. Here is a link for the manual.
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
The one leak source I would be concerned with is a leak described around the clutch pulley on page 28. If that is your leak source it’s a big project and you may need think about a service repair (BIG$ for labor but see if you can get a no cost quote) or a replacement machine if it’s not cost effective to repair. If you go the replacement direction call the Maytag CSV phone number at the end of the manual and complain, I got them to offer up a 25% rebate by talking to a supervisor on their Whirlpool, Amana, Maytag product line (don’t shoot the messenger). I’m a DIY’er and if I can’t fix this thing for under $300 with ebay parts I would move on. But let’s go one step at a time and try to ID the leak source.
To help you remove the front panel see page 33 Pic for the putty knife insertion point to raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base.
See page 41 for front panel removal don’t poke around in there with the power on just view for a water leak with a flash light while the machine fills in a Quick Wash cycle and as the machine proceeds through the wash cycle. Safety first, please follows the safety guide lines in the SM. Post again if you have questions and I’m sure I or other forum members will chime in for support. Good Luck.
Mar 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag LA212 Toploading Washer - leaks as soon as a load is started. Will continue to leak until washer is stopped. Not a small leak - there is a puddle two days later in the floor below it. Removed...
It appears that from that area the problem may be the water inlet valve or it's connections. See diagram https://www.searspartsdirect.com/model-number/LA212/3048/0153000.html?searchType=modelSearch&q=LA212&searchTerm=LA212
Nov 02, 2017 | Maytag Washing Machines
No hot water for a Maytag topload washer
Turn the water off and disconnect the hot wat hose from the spigot and the machine. There should be a screen filter in one end. Check to see if the screen is clogged. If it is then replace it. If not then replace the water valve
Jan 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
130 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
