Question about LG 32LX1D 32 in. LCD Television
Just bought a LG 32 LH20.I tried just screwing the cord that was hooked up to my other tv from my cable box into the new tv but it just says no signal.I have time warner cable with Dvr if that makes any difference.
  • 557 Answers
You need to do a first time set up. The TV has to find what channels you have. You need to set the Tv to cable as your input and then auto scan for both analog and digital channels.
Posted on Nov 15, 2009
How can i improve my tv LG LH20 42" in terms of
There are a couple of things that you can try to see if the image clears up, or is to your liking. You can adjust the resolution of the picture via the menu in the tv. You can also try resetting the tv to the factory settings, via the menu. You can also try auto configuration, which is also a menu item. If you are using a dvd/blu-ray player, use the HDMI cable for optimum picture quality.
Mar 08, 2011 | LG 42LC2D 42 in. LCD HDTV
LG 32 inch lcd tv. When you turn it on, the screen (no picture) looks like a shattered window. The set is not hooked up to cable, channels aren't set yet. I just bought the tv for my son.
You need to hook this set up to viewable source to verify if there is a defect.
Then select the source, and check for problems, then.
Is the set used or new?
Brian
Aug 02, 2008 | LG Televison & Video
Just bought an open box 32L152A-11. plugged in the electrical cord and inserted the input cable and screwed it in securely. fios box is not an "hd" so i am not i nserting a hdmi cable. i...
from what i gather you are trying to get hdtv to work with rca cables without using an hdmi cable . if this is correct then all you need is RGB cables . just like rca but they red green and blue . look on the back side of your tv , there should be a set of RGB inputs and also rca .
Feb 09, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I am getting a power only message on my brand new LH20 32" LCD tv. Any Ideas?
so when you turn it on are you getting any light on the front of the tv? Are you hearing any sound - if you take a flashlight and shine on screen are you able to see a dark picture? or just nothing when you try to turn it on? need more information to go further...
thanks,
michael
Feb 07, 2011 | LG 32LH20 32 in. LCD HDTV
I have a comcast digital converter box and i need the manual to hook it up to a tv
Here is the easiest way...
1. Connect coax cable from the wall to the "Cable in" on the cable box.
2. Connect a coax cable from the back of the TV to the "To TV" output on the back of the cable box.
3. Tune your TV to channel 3
4. Plug the power cord into the back of the cable box and into a power outlet.
5. If you do not have a picture call Comcast and ask them to send a signal to activate your new box.
6. Enjoy your new programming.....
Good Luck...
Jan 03, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do i replace the vhf/uhf connector so i can hook up the cable?
You can get a cable box that has coaxil and RCA or HDMI cables. You can run cable to box and RCA's to tv. Or use a vcr or converter box instead.
Or you can dismantle the tv, take a soldering iron and heat up the old solder joints. Then insert new connection and re-solder it in..
Sep 21, 2009 | JVC AV-32F485 32" TV
I just bought my Philips 32" lcd tv and tried to hook up the ps3
you have to first plug in the s-video before you use hdmi so you can set it to HDMI on your ps3 when you go to your setting. Then it should work. If you already did that and it still doesnt work its probably the HDMI cord
Mar 30, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Dec 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Just need to know where to plug in the red, green and blue cords
The red-blue-green outputs of the cable box are COMPONENT video, and the yellow-white-red inputs on the tv are COMPOSITE video. Although the words sound almost alike and the connectors look similar, they are incompatible signals. You'll need to change either the cable box or the tv so they match. Maybe this would be a good way to rationalize getting that new home theater system! Or maybe call your tv cable company and ask for a different box with composite video output. Once the cable box matches the tv, you don't necessarily need to change the cables. If the connectors fit, go ahead and use the cables you have.
Jul 15, 2008 | Quasar SP-3235 32" TV
LG 32LX1D 32 in. LCD Television Logo
349 people viewed this question
Computer Repairing
Computer Repairing
