I have a Whirlpool washing machine (Model # LSR6332KQ1) and two days ago it just stopped in mid cycle right at the time it is supposed to be draining and spinning. It doesn't do anything past the normal agitation, no noise, no movement, nothing. I have had several different possible solutions for this from the "lid switch" to the "condenser" to the "pump". What do you think it is?
  • 975 Answers
Sounds like THE DRAIN MOTOR PUMP , it could be clogged , usually located where the DRAIN HOSE is connected , need to take it out , clean it from any lint or debris , and try it again , AJ
Posted on Nov 15, 2009
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Whirlpool duet is stopping mid cycle and beeping
F3E2 error, Wash light flashes 3 times then 2.
Took off front lower cover, Found Manual!!!
Unscrewed filter and was so full of trash, clean and reassymbled and now works just like new. Simple fix no parts at all needed.
Jan 03, 2013 | Whirlpool Washing Machines
Water will not go out
does it stop mid cycle? do you hear a hum, like its trying to drain but can't? Something may be stuck in the pump. It may also be the lidswitch if it is just stopping and not doing anything when it's supposed to drain.
Nov 08, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Washer Stop Working after Agitate
Good day,
If it goes thru the wash cycle normally then quits, it is the lid switch assembly.
To remove the top console, be aware there are 3 locations for the screws. Bottom left and right. Bottom left and right but covered by plastic end caps that have to be unsnapped, and finally, bottom rear.
There are also 3 different lid switch styles, so use the complete model number or take the old one in to the supply house.
Here is a good tutorial on the change out procedure.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Mar 05, 2010 | Whirlpool Washing Machines
Reset whirlpool front loader
Power shd be on. Right side of control panel, "end of cycle", hold this down for 3 seconds.
Mar 21, 2009 | Whirlpool Washing Machines
Televison & Video Logo
166 people viewed this question
Top Televison & Video Experts
Electro Med Services...
