Question about AOpen MX4GVR INTEL 845GV Motherboard
Want to add memory. What kind di I need. - AOpen MX4GVR INTEL 845GV Motherboard
    Scholar:
  • 82 Answers
Hi, I've looked this up for you and the memory type is as follows.
512MB 266MHz DDR - (Double Data Rate)
The latest generation of SDRAM technology. Data is read on both the rising and the falling edge of the computer clock, thereby delivering twice the bandwidth of standard SDRAM. With DDR SDRAM, memory speed doubles without increasing the clock frequency.','300')" style="TEXT-DECORATION: none" onmouseout="hideddrivetip()" rel='nofollow' href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=15617&mfr=AOpen&model=MX4GV%2FMX4GVR%2FMX4GVR&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=15617-AOpen-MX4GV%2FMX4GVR%2FMX4GVR-GN+Motherboards&distributor=0#" ;>DDR
Non-ECC CL2.5 DIMM - (Dual In-line Memory Module) - A printed circuit board with gold contacts and memory devices. A DIMM is similar to a SIMM, but with this primary difference: unlike the metal leads on either side of a SIMM, which are *tied together* electrically, the leads on either side of a DIMM are electrically independent. ','300')" style="TEXT-DECORATION: none" onmouseout="hideddrivetip()" rel='nofollow' href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=15617&mfr=AOpen&model=MX4GV%2FMX4GVR%2FMX4GVR&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=15617-AOpen-MX4GV%2FMX4GVR%2FMX4GVR-GN+Motherboards&distributor=0#" ;>DIMM
or
1GB 266MHz DDR - (Double Data Rate)
I have supply part numbers if required.
Posted on Nov 15, 2009
  • 557 Answers
PC2700 DDR that board will support up to 2GB
I want to stop my neighbors from using my router/modem, can you help me?
Hello
All you need to do is to to enable the router security, which will enable you to add a password.
HERE is how you do it:
Type 192.168.0.1 (this will get you in your router) and once you're in, go to the "Security" tab or option and click on WEP or WPA, select the encryption, choose a password and click save or apply.
Hope this can be of help.
Kind regards
Andrea
Jun 29, 2010 | D-Link DI 514 Wireless Router (DI-514)
DI-524 resets itself.
Hi ,
Please go thru the below link...
http://forums.cnet.com/5208-7585_102-0.html?forumID=19&threadID=141999&messageID=1592458
Mar 31, 2009 | D-Link AirPlus DI-524 Wireless Router
Add di-704p to an existing network
What you want to do should be quite easy:
1. Just connect one of the LAN ports of the DI-704P to a LAN port of your WRT54G. Try using a standard network cable. If the port status lights does not turn on on both sides when you connect the cable, use a "crossover" cable. Important: leave the DI-704P WAN port empty.
2. Disable the DHCP server on your DI-704P, your WRT54G will be the DHCP server.
3. Assign a static IP address to you DI-704P, different from your WRT54G. Example, if your WRT54G has 192.168.2.1, you may assign 192.168.2.4 to your DI-704P. Make sure that the IP address you assign is outside the DHCP range configured in your WRT54G and that the subnet mask is identical on both.
You will then be able to use your print server from any wired and wireless computer and the remaining LAN ports both on the WRT54G and DI-704P.
Feb 18, 2008 | D-Link DI-704P Router
Configure to print
You may print without the D-Link Printer software in Windows 2000/XP. Here´s how: Step 1 Go to Start>Settings>Printers>Add New Printer (WinXP - Start>Printers and Faxes>Add a Printer). Step 2 Select Local Printer. Make sure to uncheck Automatically detect and install my plug and play printer. Click Next. Step 3 Select Create a New Port and select Standard TCP/IP port. Click Next. Step 4 Enter the IP address of the router (192.168.0.1). Leave the port name with the default name. Click Next. Step 5 You will get a message saying that additional port information required. Step 6 Select Custom and then click Settings. Step 7 Set Protocol to LPR. Step 8 For the LPR Settings, queue name is lp. It is case sensitive! (LP lower-case). In most cases, check LPR Byte Counting Enabled. If you cannot print, then try unchecking this. Step 9 Select OK > Finish. Step 10 Continue with the Add Printer Wizard. Choose your printer from the list or click Have Disk and point to your printer driver disk.
Feb 16, 2006 | D-Link DI 707P (DI-707P) Router
Configure to print
Feb 16, 2006 | D-Link DI-704UP - 4-Port Broadband Router...
Configure to print
Feb 16, 2006 | D-Link DI 713p Router (nwl-di-713p-r)
AOpen MX4GVR INTEL 845GV Motherboard Logo
99 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
