Question about Star Logic 17" LCD Monitor
I have starlogic 17' monitor it just stopped working no power at all no lights ,,,nothing
  • 32,281 Answers
Check the power cord, make sure it is firmly connected to the mains outlet and in the monitor. The power cord maybe faulty. try a different power cord,
If this doesn't work then the fault is in the monitor, most likely the power supply circuit.
I don't know this make and model, but it may have a blown fuse. If you are not an electronic savy person, I would advise you NOT to try to fix this problem, as there dangerous voltages in the monitor.
The cost of a repair maybe too high, I suggest you put your money towards a new LCD monitor.
Posted on Nov 15, 2009
My Starlogic monitor fails to power up. We had a recent power outage. Everything else on the computer seems to work properly however when I power up the pc the monitor will not turn on. Have manually...
Not sure if you have done this so give this a try.
* If possible, plug your Starlogic monitor into another working computer. If the Starlogic monitor works then it is the port on the original computer that has gone bad. The solution would be purchasing a new video card such as PCI or AGP video card. (Assuming all other aspects of your PC are working fine)
*However, if the monitor does not work then you know your monitor is dead. You will need to buy a new or used monitor. **You may want to barrow someone's monitor and test your original computer just to make sure the port on that original computer is fine.
Jun 16, 2010 | Star Logic 17" LCD Monitor
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
Starlogic 17" monitor not working with Vista
may need to download some drivers for it. Your operating system has nothing to do with it. Try www.driverguide.com . It also may be a hard ware fault. make sure all your connections are secure. Hope this helped.
Jun 23, 2009 | Star Logic 17" LCD Monitor
Where can i purchase another power cord for my monitor
starlogi typically use a standard computer power supply cable you may find one at any computer service center commercial or mom and pop
Jul 13, 2008 | Star Logic 17" LCD Monitor
17'' monitor whte screen power light on
have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Jun 19, 2008 | Star Logic 17" LCD Monitor
BLANK MONITOR
the signal stage of your monitor is likely to have a problem, if the cpu is working fine then troubleshoot the signal stage of your monitor or visit a local technician
Dec 06, 2007 | Star Logic 17" LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
272 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
