Question about Brother MFC-8840D All-In-One Laser Printer
Gear that drives the fuser unit
Hi there!
this all started with paper jams and grinding noises. i have opened up the printer and found the problem wich was fuser unir gear was smashed so i have chaned the fuser unit with the new one but i did not see the gear that drives the fuser unit the one that joins with the fuser unit gear was dameged ... my question is is it possible to replace that too if soo is there a special name for that gear?
Ditto. This is probably a job for an authorized service tech.
I replaced a similar gear and screwed up the duplexer. The printer work fine except that it no longer duplexes. (8840D)
If you don't get everything back in perfectly, you'll spend a lot of time messing around with it trying to fix it. And, you risk making your printer inoperable.
Posted on Feb 16, 2008
  • Brother Master
  • 1,113 Answers
Yes one can replace it but it aint no easy job, entire frame needs to come apart, I always change the whole L frame, but gear is available, set aside half a day, take pics or purchase the service manual, it still takes me 40 mins to change a frame on one of these, and you will need to go that far then some to get to just the gear in frame..
gear that drives the fuser unit - 7deadab.jpg Link to part number/price/purchase of fuser drive gear
Not such a easy job, you have been warned from one who knows OK
Good luck
Posted on Jan 09, 2008
Hp 4345 has error code 13.20.00 paper jam in tray 2 and also has a grinding noise by the fuser how can i fix it
The printer may need a "swing plate" replaced to solve the fuser noise. Remove the fuser and look at the black gear inside the printer on the left side. Do the teeth on that gear look worn ? If so that gear (swing plate) needs to be replaced. Its a hard job to do. Can you turn the fuser gears with it out of the machine without them skipping ? The tray 2 jam may just be worn rollers in tray 2 or a stuck sensor. Good luck !
Aug 06, 2013 | HP LaserJet M4345 MultiFunction Printer
I have a CL4000DN making a grinding noise when first turned on any ideas?
it is possible that the drive gear in the fuser has failed. this will cause a very loud grinding sound in the back of the unit where the paper comes out. you can order new gears for it but sometimes its easier to replace the saying all this where is the noise coming from?
Feb 09, 2011 | Ricoh CL4000DN Laser Printer
My Laserjet 5SI printer has been jamming a lot lately and now it's making a grinding noise. Should I replace the cartridge or what?
Fusers generally make grinding noises more than cartridges do. If your paper jams are in the fuser area, check the fuser first.
When you open the left side door of the printer, the fuser is installed on a shelf near the top of the cavity. To remove the fuser, grasp the left and right blue fuser release handles and rotate them to the straight up and down (vertical position. Then lift up on the fuser and remove it from the printer.
Take a close look a the at the gear located on the top left corner of the fuser - does it have broken/ bent teet or is it loose on its mounting shaft? If so, that's probably causing both the paper lams and the grinding.
Also look in the printer directly under where this gear would be if the fuser were inserted in the pinter. Do tou see a build-up of fine particles the same color as the fuser gear. If you do that's further proof the the gear is bad.
You can but a replacement fuser at several places - check out & you can get one on an exchange basis.
Oct 27, 2010 | HP LaserJet 5si Printer
Paper jams as it heads for the heater. It oges
Paper jams in the fuser (rear of the printer) are often caused by worn gears in the fusing assembly. This is usually one of the sysmptoms as well as a clicking or grinding noise which comes from the gears slipping. The solution is to replace the fuser. It is an easy fix that does not require a technician. There are only two screws that hold the fuser in place. Search for a fuser online. With shipping it should not cost you more than $75. If you are really mechanically inclined you could search just for the fuser gears but that really does require that you know what you are doing.
May 25, 2010 | HP LaserJet 4 plus Printer
Our printer is making a really loud, sort of grinding noise and then it jams. why is it doing this? When we start to use the printer in the morning it also makes the grinding noise when it's warming up.
You need to check a number of areas, but first try to determine where the noise is coming from...
1) First, where is it jamming...If under the cartridge, the cartridge drum may be too tight. If you have another or an old one (even if empty) try switching it out.
2) If the sound is coming from the front, your manual feed rollers (front) or main paper tray pickup rollers or gears (below) may be slipping.
3) If the sound is coming from the rear, check the fuser gears. It will have a main, big gear that meshes with the big drive gear (swing gear) inside the printer. The fuser is the accessed by removing the rear cover. The fuser can be very hot, as its job is to fuse the toner to the paper just before it exits into the bin. Let it cool off, then remove, inspect the gears for wear, re-seat it and test print--listening again to see if the sound is still there or gone.
4) If the sound is coming from the top rollers where the paper exits, check the gears that drive these rollers for wear and/or skipping teeth.
One of these will be the culprit. The hardest part is isolating the source of the sound.
Apr 28, 2010 | Dell 1815dn All-In-One Laser Printer
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Ricoh CL 7100 fuser jam.
The grinding noise is the clashing of gears. The fuser is composed of 2 rollers, a metal or ceramic with a heater inside (bulb) and a silicon roller to apply pressure. The 'hot' roller is geared and the silicon roller can be geared or free floating. There is at least 1 paper sensor in the the fuser to let the unit know whether paper is there and there when it should or should not be. Sometimes, the sensor gets slightly dislodged and can actually cause a jam. If you are hearing a gear clash, the paper is being pushed through the machine and instead of being pushed through the fuser, it stops because the fuser rollers are not turning. The rest of the machine keeps pushing, crinkling the paper.
If there is crinkling, then gears that drive the fuser need to be checked. It is this gear cluster and/or the fuser that need to be replaced.
Aug 03, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Grinding noise and jamming
Try to pull out paper transport unit (when open paper cassette,there is green or blue andle on the printer) and check what is wrong.Maybe just something is in improper position.
Also check paper settings on printer and driver.
If you use 80-90 gsm paper-Plain, if You using heawyveight paper(more than 105 gsm untill 200gsm) -Thick.
Dec 04, 2007 | Kyocera FS-C5030N Led Printer
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
Brother MFC-8840D All-In-One Laser Printer Logo
401 people viewed this question
James Cagle
James Cagle
Jim Keysor
