Question about Motorola Mobility RAZR V3
How to remove motherboard from back of phone. There seem to be two buried screws and the cover will not remove.
  • Motorola Mob... Master
  • 641 Answers
No there isnt 2 burried screws..ater you remove the battery ,take out the 2 visable scews..then slide a very thin screw driver along the edge..about the location of the mini usb plug location there is a tab on each side..carefully snap it open..
Posted on Nov 15, 2009
Testimonial: "Yes, it worked thanks. Now I'll clean it out and see if I can get this phone rollin' again."
How to remove cover on a soldering to change fuse
may not have a fuse
may have a transformer with a thermal cutout which may be buried inside the xfmr.
cover may be snap off or glued because it is non-serviceable
or there r screws under a label or undef rubber feet.
Jul 03, 2014 | Welding Tools
How do I open my pc to add a board
Hi You can see some screws on the back side of cpu remove 2 screws on right side from back then you can pull the cover from it. After removing cover you can see motherboard installed there if you want to install new motherboard remove all screws from motherboard and disconnect all connection from motherboard then put new board then install processor and it's fan connection all connection. Then you can use computer with new board. Let me know if you need further assistance. Thanks for using FixYa.
Aug 29, 2010 | Compaq Presario S5000NX PC Desktop
My screen is pale and when i press parts of the phone it turns back to the right resolution but it wont do that anymore.
It seems the phone fell from you or you hit the phone surface with a hard surface for your screen to be malfunctioning because it is possible that the screen is not firmed to the panel any longer and you will need to affirm it.
Get a torx6 screw driver.
First thing you need to do is to power off your, remove the baattery, and sim card, Turn the phone over and gently remove the front cover.
After you have pull off the front cover, you can go on with the torx6 screw driver to tighten all the screws that hold the screen of your phone to its panel very well and recouple the front cover back.
Put your sim card and battery to power on, with this it should stop the pale screen.
Take care.
Apr 30, 2010 | Cell Phones
Need to dry out my motorola W755
The general solution is time consuming. When my son got his wet, we popped the back cover, took the battery out, and buried the phone in a bowl of rice. The rice will leech the water out of the phone.
Sep 14, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Replace flip on my nextel i850 phone.
1. Remove battery cover and battery
2. Remove the four T-6 screws from back of the phone (you will have to raise the antenna to access one of them)
3. Seperate the housings.
4. Disconnect the flex connector/data cable that connects the back housing to the motherboard.
5. Disconnect the cable attaching the flip to the motherboard (at top of board)
6. Remove keypad from old part and put it in the new part.
7. Insert motherboard into new flip/front housing and connect cable to board.
8. Reconnect cable from back housing to motherboard
9. Replace and tighten 4 screws and you are good to go.. very easy repair.
Mar 24, 2009 | Nextel i850
Gateway 610XL Disassembly
take cover off top of base.- pry off
remove two screws that hold speaker unit, it will tilt out, disconnect cables and remove speaker.
two screws on back of base and then take off back cover.remove sheild cover.
disconnect all cables. 4 screws hold power supply in.
rca connector board has little black button holding it on. pry up and then remove board to access connecters behind.
pull all cables out towards you.
remove 6 screws that hold base to back of screen, pull up tape under where cables go thru hole.
remove base from screen.
take out screws on back of screen. carefully pry all around case to seperate.
remove back, and then sheild. there are a few screws that hold it on.
If your screen was black, then the two inverter boards could be the problem. there is one in the upper left corner and one in the lower left corner. you can by them on internet. match the partnumber, there are 2 diffent ones.
Nov 05, 2008 | Gateway Media Center 610XL PC Desktop
Removal of cooling fan
You need to disable your laptop.
follow this step:
Remove harddrive.
1. on the back of laptop, there are 2 doors. open it all. 1 of them is harddrive.
2. remove harddrive.
Remove wireless cable.
1. open 2nd door on the back, you can see rams and wireless card. unplug wireless cable from wireless card.
Remove chassis
1. Remove 2 screws on the hinge cover, so you can remove the power cover (power cover is cover that have power button).
2. after you removed power cover, removed keyboard.
3. remove 4 screws that hold lcd from chasiss. you can remove lcd now.
4. remove 3 screws under keyboard.
5. remove all screw on the back of your laptop.
6. remove upperchassis.
7. remove 2 screw that hold motherboard from lowerchasis.
8. take motherboard out from lowerchasiss.
9. now you can see the thermal fan.
Jun 19, 2008 | Acer Aspire 5050-3242 Notebook
Opening my motorola L6
remove the back cover,
take a torque 6 screw driver, its aka a nokia screw driver T6
remove the 4 screws on the back plate then u have access to the motherboard... clean the charging pin in and out using a deep brush and alcohol, only power the phone once its dried for about 4 hours
good luck
Mar 14, 2008 | Motorola Mobility L6 Cellular Phone
Memory access
for a video demo, check out this link... easy as pie!
Dec 17, 2007 | Computers & Internet
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
