Question about Pentax *ist DL Digital Camera
Using a 500mm fixed aperture lens on a Pentax ist
Using a 500mm fixed f.8 aperture lens on a Pentax ist DL in manual mode. When I snap the picture it is always underexposed. How can I correct aperture setting to lighten picture?
    Brigadier General:
  • 11,967 Answers
Use "exposure compensation" (the button with a plus/minus symbol). It allows you to lighten (toward the + side) or darken (toward the - side).
Posted on Nov 16, 2009
The Bower SLY500PN High-Power 500mm f/8 Telephoto with T-mount attached to my Nikon D5200 shows 'nop lens attched'. What is the problem?
There is no problem. The lens simply does not have the electronics for the camera to detect. You need to use the lens in Manual mode (turn the mode dial to M). You'll have to set both the shutter speed and aperture yourself, without any help from the camera's exposure meter.
You can take a picture, look at it on the back of the camera (preferably with the histogram) and adjust the exposure accordingly. Repeat until you get a good exposure.
Jan 24, 2014 | Bower Sly500pn High-power 500mm F/8...
Just got a 500mm f8.0 Telephoto Lens for my Nikon D90. When I connect it according to the instructions I am certain I have mounted the lens properly to my camera, I have a universal T mount to connect to...
The lens lacks the electronics to communicate with the camera. You must switch the camera to Manual exposure mode by turning the mode dial to M. The lens has only aperture, f/8, and so you have to control the exposure by changing the shutter speed and/or ISO. Unfortunately, the D90's light meter will not give you any help here.
You can get a general idea of the exposure by using another lens before mounting the 500mm. From there you can fine-tune the exposure by using the histogram display on the LCD monitor. This is how I do it with my D90 and 500mm lens.
Oct 27, 2010 | Nikon D90 Digital Camera with 18-105mm...
AV error whn pentax ist DL & Quantaray zoom lens attached
I've got the same problem. The problem is that the lense is loosely attached to the body. What you need to do is that when you see the Av flashing, press the lense of the camera to the body and twist the lense to the left a bit. This tightens the connection. You can then take the photo.
Feb 20, 2009 | Pentax *ist DL Digital Camera
HOW TO SET UP CAMERA WITH 500MM LENS
Hey SHUTTER HEAD,
Without knowing what camera you have I would set your camera's aperture to f/8. I would have your camera mode set to either aperture priority or manual, and leave the aperture on the camera set to f/8.
Sincerely,
Allan
Go Ahead. Use Us.
May 12, 2008 | Quantaray 500mm f/8.0 Mirror with Macro...
Pentax istD won't take pictures
i found this which seems similar
http://www.pentaxuser.co.uk/forum/topic/ist-D--HELP-444/p-0#comm_2164
"I know this is late, but the issue sounds to me like the aperture ring is not on A. and if this is a manual lens then you have to set the mode to hyper-program mode and set it to work with "other than A" on aperture."
this was my issue, i never knew that has i bought the camera 2nd hand without a manual - your issue might be something else but it's worth posting just incase
Mar 26, 2008 | Pentax *ist D Digital Camera
Pentax ist DS aperture setting problems
If you want to use the aperture ring on the lens you must enable this in the Custom settings menu. jamknight, sounds like your camera may need a professional cleaning.
Feb 01, 2008 | Pentax *ist DS Digital Camera
LENSE
Make sure the aperture ring is set to the "A" position. If the lens doesn't have an auto aperture setting then I don't think the lens will work. There is a setting called "Using Aperture Ring" that you can setup using the menu and configuration that can be set to "Permitted" that will allow you to take pictures even if the aperture ring is not set on "A", but not sure how well this work for you, but should allow the shutter to work.
Feb 02, 2007 | Pentax *ist DL (W/18-55 LENS) Digital...
Petax ist DL Focus
It could be that your lighting situation inside is darker than in the store. Since the Pentax *st DL does not have an anti-shake sensor like other new cameras, it could be telling you that the low level light will not support the aperture setting you have to acuratley stay focused.
Try using a tripod and a lower aperture setting.
Sep 08, 2005 | Pentax *ist DL Digital Camera
Program mode
MTF stands for "Modulation Transfer Function" ... It's a somewhat arcane name for one type of testing methodology used in modern lens analysis. The *ist D's MTF priority program mode sets the "best" aperture to use for a given ISO setting and meter reading based upon lens information encoded in the latest FA series lenses. Earlier series lenses do not include MTF information in their communication with the camera so I suspect it defaults to Normal program mode when non-FA lenses are used.
Sep 08, 2005 | Pentax *ist D Digital Camera
Will a lenses without the A setting on the apeture ring work on a DS
They will - fully open in Av mode, and with any aperture in manual mode - after you allow the Ds through the custom settings menu to use aperture settings different then "A". To choose correct exposure with such a lens in manual mode you can use the AE-button - it stops down the aperture, reads the EV and sets the shutter speed according to the chosen aperture.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Pentax *ist DL Digital Camera Logo
124 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
