Question about Garden
I want to change the transmission belt on a Cub Cadet LT 1045. Everything looks pretty straight forward except the engine pulley. It looks like engine has to be unbolted and lifted high enough to get the belt off the pulley because the belt guides are welded to the frame. If that is the case, how do do I get the blade clutch off?
You can carefully bend back the guides on frame, push in the clutch pedel and secure it with a piece of rope or a bungee cord. (this allows slack in the belt to remove it.
If you wanted to loosen the motor which is time comsuming, you would need an impact wrench to loosen bolt on pto
Posted on Nov 20, 2009
Cub cadet ltx 1045 transmission will not disengage
Go to homedepot.com then search for cub cadet ltx1045 illustrated parts manual go to page 18 look at parts 51, 52, 53 maybe the spring 51 is broken or something has 52 or 53 stuck.
Sep 04, 2017 | Cub Cadet Garden
I have a 2006 Cub cadet LT 1045. My model only has one idle pulley. I am having a hard time keeping belts on. Does anyone know a fix for this
have you got the belt on the right side of the idler pulley
the back of the belt should be running on the pulley
Sep 25, 2015 | Cub Cadet Garden
I need part no. for manufacture date 2005 cub cadet lt 1045 modle ps-sv600 0009 pto clutch
I have a 2005 Cub Cadet LT1042, Spec. No. PS-SV590-0003, but my parts manual also lists part numbers for the LT1045. The clutch part no. given for your model is 717-04174.
Hope this is helpful.
Paul
May 10, 2013 | Oregon Scientific Electric PTO Clutch for...
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Cub cadet belt keeps coming off the deck
Link to see video of the Fix for cubcadet deck belt coming off can be viewed here: http://www.youtube.com/watch?v=Pd4nYovcnvY
Apr 21, 2012 | Cub Cadet Garden
Need a transmission belt diagram for cub cadet 1000 series
hi there
pauly46 here
i can only suppose its a LT 1018 up ward
here is web site for that model
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1018+Tractor&dn=0125100003
or you can go to here and choose from this web site area list
http://www.partstree.com/parts/?lc=cub_cadet&mh=12
choose your model from list , then go to drive system
view belt diagram ,
you could save a copy or print them straight off web page
cheers hope it helps
pauly46
Apr 30, 2011 | Cub Cadet Garden
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
188 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
