Question about Dell Inspiron 6000 Notebook
Connection to wireless internet
I am not certain this is a problem with the computer or the network, however our admin assistance is on the network and has no problems with it that can not be easily solved.
Here is the problem:
We are using Netgear Lan that goes to a WAN D-Link wireless internet connection. My assistant can connect on her computer, but I can not connect on mine. I began using a 3G connection and now that does not work either. Is there something built into a Dell laptop that needs to be disabled or changed before connecting via a wireless system? Other suggestions? We have tried basic troubleshooting. Everything that we have tried points to a problem with the computer.
Any advice would be appreciated.
    Novelist:
  • 101 Answers
Hi Dire,
Try this link, and see if it helps.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&treeid=C5450E3B88432610E030A68F27286D46&journalid=4327770B4FB1797CE040A68F5A2836D7&Query=d2lyZWxlc3M=&SystemID=INS_PNT_6000&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true
Another idea is to pickup a USB Wireless adapter, Even if you just borrow one from a friend, and try. See if you can connect with it.
You can also go to Start>Control Panel>System>click on the hardware tab, and then on Device Manager.Click on the + sign by Network Adatpers, Find your Wireless network adapter, right click on it, and choose Uninstall. Reboot to have Windows reinstall the wireless.
Hope some of these help.
Good Luck
Posted on Jan 09, 2008
6ya staff
SOURCE:
How do I set my kids wii, to get the internet? I am getting an error code 51031, I cannot find my paper that tells me what my ssid is. How would I go about finding out that information?
To find the SSID, you can always just turn on the wireless on a laptop and see which network your home network is. If that's not available, you can connect to the router via an ethernet connection and visit the router setup page (usually 192.168.1.1 or something like that), put in your username and password (typically admin/admin or admin/(no password) or admin/password) and view the wireless settings to see the SSID.
According to the wii information page (located here), there could be several issues. Double check your SSID to be certain, also check this page to see if your router is known to be compatible.
Jul 20, 2011 | Nintendo Computers & Internet
Where do I look on my "main" computer (hard wired
Hi dkusner,
Welcome to Fixya. If you need your Wep/Wpa Key (Passphrase) we can access the Wireless Settings Page of the router to obtain the information needed.
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key (Wep/Wpa Key) or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Don't forget to say thanks. Thanks for using Fixya
Feb 10, 2011 | NetGear WGR614 Wireless Router
Create a password for wireless internet connection
Hi. Open your browser and go to http://192.168.1.1
the default username and password is admin / admin.
Once you are inside the router, you will see on the left the menu such as network map, operation mode, advanced settings. Under advanced settings you will see the Wireless configuration where you can change the SSID (name of the wireless network) to any name you want. Then on the security you can select either WEP or WPA, i would recommend WPA and you set the password (letters and numbers or just letters) and save the settings and that's it.
Try to do this on a computer directly connected to the router (via ethernet cable) because any change on the wireless will disconnect you.
I hope this helps. Please do not forget to write and provide positive feedback for our fast/free support today. :D
May 25, 2010 | ASUS RTN12 4 Port 10100 Wireless N Router...
Dsl wont pass thru router wired or wireless I have reset the router several times, the computer shows connected ,signal strenght excellent, but will not connect to the internet wired or wireless as long as...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My wireless modem is not working
3.Configure your wireless router
Using the network cable that came with your wireless router, you should temporarily connect your computer to one of the open network ports on your wireless router (any port that isn't labeled Internet, WAN, or WLAN). If you need to, turn your computer on. It should automatically connect to your router.
Next, open Internet Explorer and type in the address to configure your router.
You might be prompted for a password. The address and password you use will vary depending on what type of router you have, so refer to the instructions included with your router.
As a quick reference, this table shows the default addresses, usernames, and passwords for some common router manufacturers.
Router
Address
Username
Password
3Com
http://192.168.1.1
admin
admin
D-Link
http://192.168.0.1
admin
Linksys
http://192.168.1.1
admin
admin
Microsoft Broadband
http://192.168.2.1
admin
admin
Netgear
http://192.168.0.1
admin
password
Internet Explorer will show your router's configuration page. Most of the default settings should be fine, but you should configure three things:
  1. Your wireless network name, known as the SSID. This name identifies your network. You should choose something unique that none of your neighbors will be using.
  2. Wireless encryption (WEP) or Wi-Fi Protected Access (WPA), which help protect your wireless network. For most routers, you will provide a passphrase that your router uses to generate several keys. Make sure your passphrase is unique and long (you don't need to memorize it).
  3. Your administrative password, which controls your wireless network. Just like any other password, it should not be a word that you can find in the dictionary, and it should be a combination of letters, numbers, and symbols. Be sure you can remember this password, because you'll need it if you ever have to change your router's settings.
The exact steps you follow to configure these settings will vary depending on the type of router you have. After each configuration setting, be sure to click Save Settings, Apply, or OK to save your changes.
Now, you should disconnect the network cable from your computer.
4. Connect your computers to the wireless network If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Mar 25, 2010 | Compaq Presario Notebook
Can not connect to my wireless router
1. Choose your wireless equipment The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
  • Broadband Internet connection
  • Wireless router
  • A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2. Connect your wireless router Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
  • If you currently have your computer connected directly to your modem: Unplug the network cable from the back of your computer, and plug it into the port labeled Internet, WAN, or WLAN on the back of your router.
  • If you do not currently have a computer connected to the Internet: Plug one end of a network cable (included with your router) into your modem, and plug the other end of the network cable into the Internet, WAN, or WLAN port on your wireless router.
  • If you currently have your computer connected to a router: Unplug the network cable connected to the Internet, WAN, or WLAN port from your current router, and plug this end of the cable into the Internet, WAN, or WLAN port on your wireless router. Then, unplug any other network cables, and plug them into the available ports on your wireless router. You no longer need your original router, because your new wireless router replaces it.
  • 3. Configure your wireless router
  • Using the network cable that came with your wireless router, you should temporarily connect your computer to one of the open network ports on your wireless router (any port that isn't labeled Internet, WAN, or WLAN). If you need to, turn your computer on. It should automatically connect to your router.
    Router
    Address
    Username
    Password
    3Com
    http://192.168.1.1
    admin
    admin
    D-Link
    http://192.168.0.1
    admin
    Linksys
    http://192.168.1.1
    admin
    admin
    Microsoft Broadband
    http://192.168.2.1
    admin
    admin
    Netgear
    http://192.168.0.1
    admin
    password
Mar 24, 2010 | HP Pavilion dv9000z Notebook
I changed from DSL to Cable internet service. I
For that you need to access your router configuration.
Connect your router to computer with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router .
Click on WAN settings and set network settings of your internet service provider.If you want ip address from your network then enable DHCP.
If you want wireless click on wireless and set security as WEP if you want to secure.
Dec 19, 2009 | Linksys Wireless-G WPS54G Print Server
Wireless g router trouble no conectivity
You have to enable DHCP in your wi fi router.
For that connect your wi fi router to youe computer with ethernet cable.
Then access it with following link
http://192.168.1.1
or
http://192.168.0.1
then Enable DHCP.
Then save settings and exit router.
Also check your wi fi network adapter property Check TCP /IP settings enable ip get automatically.
Then it works fine.
Let me know if you need more assistance.
Thanks.
Sep 30, 2009 | Linksys Wireless-G WRT54G Router
Power
1.
efefddd.jpg Next, connect your router to your modem:
5641429.jpg Next, plug in and turn on your cable or DSL modem. Wait a few minutes to give it time to connect to the Internet, and then plug in and turn on your wireless router. After a minute, the Internet, WAN, or WLAN light on your wireless router should light up, indicating that it has successfully connected to your modem.
3.
8d8f1b2.jpg Using the network cable that came with your wireless router, you should temporarily connect your computer to one of the open network ports on your wireless router (any port that isn't labeled Internet, WAN, or WLAN). If you need to, turn your computer on. It should automatically connect to your router.
Router Address Username Password 3Com
http://192.168.1.1
admin
admin
D-Link
http://192.168.0.1
admin
ts.gif Linksys
http://192.168.1.1
admin
admin
Microsoft Broadband
http://192.168.2.1
admin
admin
Netgear
http://192.168.0.1
admin
password
1.
2.
3.
4.
If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows XP will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Note: The steps below only apply if you're using Windows XP Service Pack 2. If you're running Windows XP and you don't have Service Pack 2 yet, plug your computer into your wireless router and download and install Windows XP Service Pack 2.
Windows XP should show an icon with a notification that says it has found a wireless network.
5118333.gif Follow these steps to connect your computer to your wireless network:
1.
Right-click the wireless network icon in the lower-right corner of your screen, and then click View Available Wireless Networks. If you run into any problems, consult the documentation that came with your network adapter. Don't be afraid to call their tech support.
2.
The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.5914228.gif 3.
Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
4.
Windows XP will show its progress as it connects to your network. After you're connected, you can now close the Wireless Network Connection window. You're done.
Note: If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key.
Jul 03, 2008 | Acer Aspire 5100 Notebook
Lost internet connection?toasted router?
You will need to create your PPPOE internet connection on the router using your ISP username and password, access the router by opening internet explorer and type in the ip address of the router (example) > http://192.168.2.1 the router logon window will appear, use the username " leave blank" and the password "admin" -or- username "admin" with password 1234. Go into internet connections Select PPPOE connection enter your ISP username and password. restart the router and computer this should establish your internet connection. BPCS
Dec 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
Dell Inspiron 6000 Notebook Logo
93 people viewed this question
Ekse
Clive
Clive
Alun Cox
