Question about Whirlpool GEW9878LW Electric Dryer
I have a Whirlpool Gold dryer, GEW9878LW. The drum isn't turning when i hit start, HOWEVER it does turn when I manually push it. Everything I read says it's probably the belt. I can't figure out where the belt it? I've looked in all my manuals & trouble shooting guide & it's not listed. I'm willing to replace it if i can figure out where it is. LOL Thanks!
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Nov 15, 2009
Won't turn on
next to the motor could be a silver capacitor..................may be duff........with the lid off............ powered on..........push the top of the drum...........if it starts going........its the capacitor................be careful..........
cheers
Jul 29, 2017 | Whirlpool GEW9250 Electric Dryer
GEW9878PW! electric dryer, evidently it isn't going into cool down mode
On the late models with electronic controls you either have a bad control OR a bad thermistor. The thermister mounts on the blower housing and the control measure the resistance drop on it as them clothes get dryer. That along with a pair of sensors that detect moisture inside the drum. As the clothes get dryer the less moisture is sensed until the control advances over to cooldown and finally off. So if the thermister is not working correct the temp would be off. The control is way more money than the thermister. I would clean it up first and make sure no air restrictions are causing overheating.
SERVICE MANUAL FOR DUET DRYER IF ON MY MANUAL PAGE AND FREE
Sep 30, 2012 | Whirlpool GEW9878LW Electric Dryer
Whirlpool LER5636PQ1 DRYER starts when I hold the button then shuts off
Your motor has gone bad. Think of the motor as a starter in a car. When you turn the key (press the start button) power is applied to the starter, to be specific, the stator also called the start winding, same as the dryer. Then the rotor takes over and the stator drops off. With your machine the rotor isn't engaging and the stator is taking the load and shutting down.
May 27, 2012 | Whirlpool Dryers
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
GEW9878LW Electric Dryer: Whirpool Dryer - Model # GEW9878PWO - Serial # MS4...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 18, 2010 | Whirlpool GEW9878LW Electric Dryer
Have a whirlpool gb awz2303 heats ok but drum would'nt turn turned drum around went ok for about a month then same thing happend do you think its the belt streched
By what your saying, yes the drum belt is stretched and or is sliding out of track. You can check this by removing the back panel, be sure to shut or unplug power first, then you will be able to see what i am talking about. hope this helps
Oct 07, 2009 | Whirlpool GEW9878LW Electric Dryer
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
Whirlpool GEW9878LW Electric Dryer Logo
151 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
