Question about Broan-NuTone CV353 Central Vacuum
Wont turn off - runs constantly - Broan-NuTone CV353 Central Vacuum
    Scholar:
  • 70 Answers
It sounds to me that the relay has stuck contacts. Try tapping the relay with the HANDLE of a screwdriver if you can find it. BE SURE TO UNPLUG THE UNIT BEFORE YOU OPEN THE UNIT !! Most centrals now have circuit boards and not seperate parts like earlier vacs which means you will have to replace the board.
Another thing to try is to take loose one of the low voltage wires to see if the unit will stop. If it does, you have a short with the wires touching somewhere along the line.
I hope that I have helped.
Joe
Posted on Nov 15, 2009
Power head brush wont run
Could have a loos belt, check and replace if necessary.
Nov 23, 2013 | Vacuums
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
When you turn the sewing machine on it constantly keeps on going almost like you have your foot on the pedal all the time the machine is a contessa 410 model
the foot pedal controls the voltage to the machine. If it is running to fast then the foot control is bad
Apr 18, 2011 | Vacuums
Sebo Vacuum runs intermittently and keeps cutting out and restarting
There could be numerous reasons for this. What I would try in this order to help troubleshoot is this:
1. If you wiggle the power cord near where it inserts into the vacuum cleaner itself, does the vacuum turn on and off constantly? If so, you have a damaged cord or loose connections that need to be fixed.
2. Has the bag been emptied, and if the vacuum has a filter element, has this been cleaned? Vacuums may cutout if they get too hot. A vacuum can overheat if either the bag is full, the filter is blocked, or there are other obstructions to airflow, which cause the motor to work harder and draw more voltage, resulting in more heat. It may have a thermal cutoff which is tripping constantly. Solution is to ensure bag is not full, or less than 3/4 full, any air filters are cleaned and check for any other obstructions in the air flow paths.
3. Ensure the power supply is adequate for the vacuum. Try running it without long extension cords if you have been using those.
4. Check and clean the switch. Sticky or dust contacts on switches can cause variable cycling (cutting out and restarting).
Hope that helps!
Mar 11, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
DC 17 UPRIGHT BRUSH MOTOR WONT STAY RUNNING. TURN
have a look at the filters first as it sounds like you blokeage
Oct 31, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My new vaccum wont pick up cat hair
i would return this vacuum while it is still under warranty.
Aug 22, 2009 | Vacuums
Motor shaft wont turn on EL2050
Have you tried running the brush motor without a belt on it? Does it not spin without the belt? If so, you may have worn motor brushes (not too expensive parts, but make sure you order both brushes, or make sure they are sold as a set). If your motor is in good condition (you can check the brush motor by hooking it up to a momentary power source NEVER apply constant power to a motor that is not mounted to either the machine or something to keep it from running away) There is sometimes a switch down towards the brush head assembly that could be bad.
Jan 19, 2009 | Electrolux Central Vacuum
Loud noise when running.
Bad bearing or fan in the motor is most likely the problem. You would have to replace the motor.
Mar 02, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Broan-NuTone CV353 Central Vacuum Logo
172 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
