Question about Sunbeam SG7621SP Grill
Only 1 side of my sunbeam H85KQ mattress pad will heat. How can I troubleshoot for a fix?
  • Anonymous Mar 17, 2014
    Sunbeam Mattress Pad Heater Blinks no heat
    Scholar:
  • 53 Answers
If your model has two heat control thermostats, its possible that there is a fault with one of the thermostats.
Worse would be that the electric cable that runs thru the blanket is broken.
You would need specialised test equipment to find where the break is, unless you can actually feel the cable is split when you run it through your fingers.
Normally, if the electric cable is broken, the blanket is not servicable, because you would have to cut into the cover material to try find the break and replacing the cable is impossible outside of the factory.
Posted on Nov 18, 2009
Sunbeam heated mattress pad blinking F2 on one side. How do I turn it off?
https://www.manualslib.com/manual/532253/Sunbeam-Sleep-Warm-Sleep-Well.html?page=12
Jan 06, 2018 | Sunbeam Heating & Cooling
I have a sunbeam two control mattress heated pad. One side works fine but the other will show a F error when put on preheat..
look for creeses in liquid lines. also check fualty wiring for voltage. switch power to pads if it heats look at power supply
Jan 03, 2018 | Sunbeam Heating & Cooling
Why only one side get hot
These are made with a wire in them that heats up. Yours probably has a wire for each side, and one has gone bad. DO NOT continue to use it. I suggest you take it to a qualified repair technician or replace it. It could cause a fire or electric shock.
Dec 07, 2015 | Sunbeam California King Arlington Heated...
I am looking for a replacement for 1 of the controls for my heated mattress pad. Where can I find 1?
www.sunbeam.com/.../bedding/controls/bedding-contr...
Sunbeam ProductsHow do dual controls work? The dual ... What if my control does not regulate my side of the warming product? ... Where can I purchase replacement controls?
Finding Replacement Cords and Controls for an Electric ...
www.thriftyfun.com/Finding-Replacement-Cords-and-Controls-for-an-El...
... blanket. Finding a replacement cord or a control for an electric blanket can be difficult. ... My blanket was under warranty and I got one for free. If yours is out of ...
Finding Replacement Controls for a Heated Mattress Pad ...
www.thriftyfun.com/Finding-Replacement-Controls-for-a-Heated-Mattre...
This is a guide about finding replacement controls for a heated mattress pad. It can be very frustrating to find replacement ... Read all 1 Answer ... Where can I findreplacement controllers for my Living Quarters heated mattress pad? By Steve.
Replacement Controls for a Sealy Electric Blanket ' ThriftyFun
Dec 07, 2015 | Sealy Heated Queen Size Mattress Pad - -
One control works and not the other control
I have a Sunbeam electric blanket. One control is blinking F2. How do turn that off?
Mar 05, 2014 | Sunbeam California King Arlington Heated...
I have a Rest and Relieve Therapeutic King Heated Mattress Pad that I have lost the remote control for. where can I purchase a replacement remote?
You should try to contact the supplier of your mattress cover. If they have a website, you can check their website to check if they provide the separate remote for that particular mattress. Even if they don\'t, you can contact them asking the solution.
Jack
Jan 21, 2013 | Sunbeam Bedding, Rest and Relieve...
I need instructions on operating a remote to Sunbeam,Cal-King, electric mattress pad.
Which model Sunbeam mattress pad do you have? Sunbeam has some of their manuals here: http://www.sunbeam.com/manuals.aspx . The electric bedding share a manual. The direct link is http://www.sunbeam.com/BeddingManuals/SunbeamBedding/Universal.pdf .Make sure that you are using the master control for your side of the bed (that's the one closest to the plug for the wall outlet).
You may need to turn on the second control and set it to 0 at night. If you still are having a problem with the heat being uneven, you might need a replacement mattress pad. I know we've replaced several electric blankets or mattress pads due to problems with the control/uneven heat.
I hope this helps.
Jan 25, 2012 | Heating & Cooling
Greetings, I purchased a full size heated mattress pad with a single off-hi-lo-off control switch several decades ago and the fabric covering the heater elements has deteriorated thus exposing the...
I don;t think there is any repair that is possible and you will need to replace your mattress pad. I would recommend you contact sunbeam directly at sunbeam.com and see if this model has a lifetime guarentee.I tried but they wanted to know how old it was and other info that I could not provide.
If you have had this good of service from their product then I would let them know and maybe they will work with you.
I have had good results contacting companies and praising their products and it don't cost much to try. Thank you
Jan 16, 2011 | Sunbeam Heating & Cooling
The controller on my heated mattress pad blinks
I had same problem. Make sure plug is all the way in and locked.
Oct 07, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Sunbeam SG7621SP Grill Logo
564 people viewed this question
Top Sunbeam Grilling Experts
Gil Shultz
David White
Steve Pack
Steve Pack
Are you a Sunbeam Grilling Expert? Answer questions, earn points and help others
