Question about Kodak EasyShare C875 Digital Camera
Flash stopped working. How do I get to the flash?
    Genius:
  • Kodak Master
  • 1,099 Answers
Flash 380EX with EOS 40D and 18-55 Canon lens. At all zoom positions under 55mm the flash is too weak and the pictures are underexposed. At 55 mm flash works fine. Pushing "*" button does NOT...
You may need to adjust the flash exposure compensation about 1 stop or try 1 stop and if it's still not enough go a stop and a third. What's happening is the flash is being dispersed over a much wider field of view and the fall off is so much greater then at 50mm which the beam is narrower. The 380 EX works well from 35mm through 135mm. After that it still works if you are in close say 20 to 30 feet.
May 02, 2011 | Canon 380EX TTL Flash
Flash will not work
Before you give up on the camera:
There are many setting that can affect whether the flash works or not.
You may have inadvertently set something that is stopping the flash from working.
Get out your User Manuals and use the index at the back of the book.
Look for something about "Resetting the camera".
This will reset the camera to factory specifications.
Then see if the flash works.
If that does not work ... recharge the battery and try again.
If that does not work, the flash is likely dead.
May 30, 2010 | Canon PowerShot A590 IS Digital Camera
Cannot stop on board flash from flashing in
In commander mode, the onboard flash must flash. How else would it communicate with your slave flash(es)? Depending on your settings, almost all of the communications can be done before the picture is taken.
Is the onboard flash negatively impacting your photos?
Jan 06, 2010 | Nikon DSLR D90 Digital Camera
Jan 05, 2010 | Canon PowerShot A590 IS Digital Camera
Fujifilm FinePix 3800 flash will not work
Normally when the flash stops working it is because the capacitor the camera uses to store the flash power ( that is what charges..not the bulb) burns out. This is a very difficult repair and should only be completed by a camera technician.
If the repair is over 10 dollars I would suggest a new camera.
Jan 28, 2009 | Fuji FinePix 3800 Digital Camera
I had the same problem, "BBWS" found this "solution":
Turn the camera on as if to take photos (not to review photos).
Press "Home" (upper left corner)
Press the camera tab (bottom left-most tab)
Press "Scene Selection (SCN)"
Press "OK" at the "Select type of scene" prompt
However, I still don't have flash available in the PGM or AUTO modes, which tells me it is still broken.
Jul 13, 2008 | Sony Cybershot DSC-T200 Digital Camera
Flash not working
Hey influenza,
Nearly dropping the camera should not affect the operation of the flash unless the flash was extended and you caught the camera by the flash and it is somehow physically damaged. What is more likely is the camera is either set to a mode that doesn't allow the flash to operate, or the flash is set to auto off. Directions on how to turn the flash on or off start on page 34 of your camera manual. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.nikonusa.com/pdf/manuals/noprint/D40_noprint.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jul 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash
Flash board is located on the top of the camera and it contains your shutter and video buttons. It also contains a 330 V capacitor that stays charged. If there is no charge, then the camera will say flash charging. If the camera persistently says flash charging, then the flash on your camera stopped working.
I found a flash board on ebay for 10 bucks plus shipping. To repair the flash involves in taking the camera apart. It is can be tedious but it is rather easy to do. If you are interested, I send you detail instructions.
May 09, 2008 | HP Photosmart M407 Digital Camera
The flash isn't working
might be obvious, but try replacing the batteries. also during continuous shot mode, flash will be automatically set to off. otherwise contact samsung for repair estimate. Good luck
Mar 13, 2006 | Samsung Digimax A6 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
83 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
