Question about HP Cameras
Camera lens stuck and wont go back in - HP Cameras
    President:
  • 2,761 Answers
If you've recently dropped the camera you've likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either condition will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 15, 2009
Lens wont go back in
The mechanical rectactors are probably worn out. Try turning it on and off again. If that doesn't work, try pushing gently the lens with your palm while shutting it off, maybe the rectractors need a bit of help or are just stuck and may fix themselves after you help them rectact the lens once.
Mar 05, 2014 | Canon PowerShot A580 Digital Camera
Camera stuck with lens out & wont turn on =/
This happens with many cameras, whatever you do, do not force the lens back. You will see this as a suggestion on some blogs. Doing it might further damage the camera lens and other parts.
Here is a repair place that is very reliable: http://www.teleplancamerarepair.com/Olympus_FE_FE-370
WHen sending it in make sure you cushion it so it doesn't get worse when shipping.
Jul 04, 2010 | Olympus FE-370 Digital Camera
The lens is stuck out and wont go back in have
turn cam on and grab hold of lens and try to wiggle it back into alignment.
May 12, 2010 | Kodak Easyshare M893 Digital Camera
Kodak Easy Share Z1275 stuck lens
**** a very common problem with most cameras. There hasn't been much of a solution for this problem except to try to wiggle the lens zoom while pushing and holding the power button.
Also make sure you have brand new batteries installed. Even the slightest dead battery will cause a problem.
Jun 02, 2009 | Kodak EasyShare Z1275 Digital Camera
(lens error) my camera lens wont go back in
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 19, 2009 | Nikon COOLPIX L18 Digital Camera
The lens wont go back in and it wont turn on help
Sorry to tell you but you have to send the camera in for repairs. The 1st frame and cam frame could be damaged or could need resetting and alignment. Please dont force it back into the camera body as you could cause more damage which would make the camera unrepairable/too costly.
May 12, 2009 | Cameras
Lens stuck/lens error
Hello
there are tiny plastic gears inside and may have chipped or a small piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Aug 19, 2008 | Nikon COOLPIX L10 Digital Camera
Camera lens stuck out and wont turn on
I purchased my Canon SD 1000 a couple months ago and as soon as I owned it one month I had lens problems. Stuck shut stuck open and now its still stuck open. I take care of my camera and carry it in a case all the time. This is my second rodeo and there wont be a 3rd,
CANON IS DONE GETTING MY MONEY
Jan 20, 2008 | Nikon COOLPIX L2 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Cameras Logo
83 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
