Question about Vizio P4221 Television
Vizio P42 lines on screen
When my tv turns you can see the picture then it suddenly turns to 4 or 5 big horizontal blue,red,white,yellow,black in color. My front power,menu,volume,and channel buttons also do not work.
  • 2 more comments
  • viziop42 Jan 13, 2008
    I have the same problem. Wide colored horizontal lines.
  • eddiefinesse Nov 12, 2008
    I have the same problem plus a red 1inch vertical line on the on the right side as well.
  • peglegpo Dec 19, 2008
    I have black and white vertical lines across the whole screen on my Vizio 37 inch. Also it will not shut off or respond to the remote. Only way to turn it off is unplug it. HELP !! Geek Squad wants $350.00 to fix it .
  • Anonymous Apr 12, 2009
    the same thing
3 Suggested Answers
SOURCE: $$$$ fixed
i had the same horz. lines in my t.v. I called everywhere and ended up fixing it myself.(The solution on my t.v. was to unplug the set hold in both channel buttons and plug the set in at the same time you hold the buttons) it then reset the t.v. lots of luck.Bob p.s let me know if it helped you.
Posted on Apr 30, 2008
SOURCE: Vizio P42 model Sp42 A
I had the same problem. I bought the TV with the same symptoms and couldn't find a solution. So just on a hunch I tried different button combinations on the front of the TV while I turned the main power switch on in the rear. One I got to the Channel up and Channel down the TV came to life and works great. So just hold those 2 buttons down at the same time while you flip the switch on the back. Hold them for about 10 seconds and then you should be good to go.
Posted on May 30, 2010
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Red/Orange horizontal lines
it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
Screen flashing ribbons of color over picture
i think its your cable box. check it carefully.
May 25, 2009 | Vizio VA26L 26 in. LCD HDTV
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Vizio P42 Plasma HDTV10A
THE CABLE INPUT IS SERVED ON 22" VIZIO HOW AND WERE CAN I GO TO FIX THIS PROBLEM IN ATLANTA
May 19, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Apr 05, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
$$$$ fixed
Apr 02, 2008 | Televison & Video
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Vizio p42
had the same problem had the main powerboard replaced they were out of stock and had to send mine in and vizio referbed it I was told it was a common problem with this unit
Feb 01, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P4221 Television Logo
154 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
