Question about Dell Latitude D600 Notebook
Dell Latitude cpi still wont start
I tried it with out the battery, (ac only) and it still flashes lights for a few seconds then turns itself back off. Any other suggestions?
  • 4kalawala Jan 09, 2008
    Actualy ITS FIXED!!! When I put the battery back in and hit the button it came on!!!!!!!!!!!! THANK YOU!!!!!!!!!!!!!!
  • 1,601 Answers
Thanks for the update!!
Posted on Jan 09, 2008
My Dell Laptop D610 wont turn on. It was on, I
Turn off laptop, Remove the battery and the power cable and press the power button for about 30 seconds.
Check for light on AC adapter.
Try with battery alone. Try with AC adapter alone.
Try with a different adapter of the same kind.
else the issue could be with the main board for which I would request you to contact the manufacturer.
Sep 11, 2009 | Dell Latitude D610 Notebook
Dell Latitude will not turn on.
this time your DELL LATITUDE is hang-up, why because the motherboard find some devices connected which are no longer exist...
Here's what you do for now, remove the jumper switch to reset the cmos setting to clear and back to normal, you can see jumper very near to the cmos battery...
if the problems exist again tell me how many numbers of beeps.. heres my email:
Jul 12, 2009 | Computers & Internet
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Won't turn on
Have you tried a hard reset hold the Ctrl+R key at the same time as switching on the computer will sometimes clear the problem did on mine
Jan 19, 2009 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell c640 not charging battery
I have found a few things with this model, first if the laptop works on ac power when the battery is out then try pushing the button on the battery itself and see how many lights light up. If they are not green replace the battery it just wore out. Second if you can wiggle the power cord and you see the charge light flash on and off then the solder joints are cracked on the main board and you will have to take the main board out of the case and drill out the 3 rivets on the metal bracket covering the plug and bend it out of the way then there are a small brown and a small black block near the plug resolder the ends of these facing the plug. bend the bracket back into place and epoxy it where it was. put the main board back in the case hook all the stuff back up and now it will charge your battery. If you are not good at this stuff I would not try it yourself. I have fixed 2 c640s this way and it is slow careful work.
Jun 24, 2008 | Dell Latitude C640 Notebook
DELL Latitude CPi A Series
Something to try would be to re-seat the ram and harddrive.
just take them out and then put them back in and try again. I would try with the battery out and just the ac power plugged in.
Being that it was bought off eBay, realistically it probably got banged around a little bit. Sometimes if one of the devices are not making a real good contact it can cause these problems. I have also seen bad batteries cause this problem.
This is not necessarily going to fix your problem, but it has occasionally worked for me in the past and it is a very quick and free thing to try.
Mar 20, 2008 | Dell Latitude CPI Notebook
Laptop wont start
Some problems would be,
1. some hardware loose connection
Feb 13, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
My c600 is not puttin power in battery
if its the battery with a press button that lights up 5 green lights.. if u hold it for about 6 seconds it should light up all or some in a row like 000.. ( depends on charge it has) after 6 seconds none should flash , they should turn off . if any do flash or led green are missing in between its likely a bad battery.
Sep 29, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Latitude D600 Notebook Logo
85 people viewed this question
Alun Cox
