Question about Sony ES Series Home Theater A/V Receiver STR-DA5400ES 7.1 Channels
Ihave a sony str da5400es reciever & remote code
Ihave a sony str da5400es reciever. is there a remote code for the sony remote so that i can operate a direct tv hd sat box.
SOURCE: I NEED INSTRUCTIONS ON HOW TO CONNECT ALL COMPONENTS TO THE SONY STR-DE598 RECIEVER
codes for remote
Posted on Dec 23, 2007
  • 85 Answers
SOURCE: operating instructions for sony str-d565 receiver
this is a link just make sure to disable protected mode in internet explorer sometimes it has problems with links
http://www.docs.sony.com/release/STRD665.PDF
Posted on Feb 23, 2009
  • 382 Answers
SOURCE: Picture/audio problems on my HDTV
This is a cable box problem. Could be a lack of signal stregnth or bad HDMI output.
The SA boxes have a very bad history of this, try using the component video output and see if the problem persists.
The HDMI is a real glass jaw of those boxes; but this problem could absolutly be your incoming signal...high def channels require more signal strength and that is what causes audio drops, pixilation and flicker.
If it was the HDMI in the receiver/tv you would get:
- Black screen, Pink fuzz or green streak dropouts.
- "Fireflies"
- Audio cutting in and out
- Not pixilation!
So what is my approach? If the box is rented or under warranty get it replaced. If the problem persists then call your cable company and arrange a service call at their expense.
If the box is not under warrenty go ahead and call the cable company and complain about a poor signal. If the signal is good, use the component video output...it looks almost identical anyway.
Let me know if this helps,
Cheers!
Posted on Feb 03, 2010
  • 49 Answers
SOURCE: Sony STR-DG 820 Receiver experiences sound & vision drop-outs.
your on track . better than i could have accomplished. no updates on this receiver. strange how it worked for 9 months,though.I am inclined towards the v-box as well. but i have not been able to get any info about this box.
Posted on Mar 04, 2010
  • 222 Answers
SOURCE: How to know Amp and volts Fuses of a volume board RECEIVER SET-DE
Power output divide it by 110
example 600 / 100 + 5.45
you need to replace it with 6 Amperes or the closest as long as it is not lower than 6
Posted on Jun 06, 2010
How do I program a Sony STR-K670P Reciever to a Sony Universally Remote RM-VZ220 Sears says it's compatible but because it's a reciever not a DVD player I don't know how to program it it because it...
Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
May 23, 2014 | Televison & Video
Str-de875. Remote is suddenly not making the amp work. the remote still turns tv on/off
does the light blink more than once when you select the 'contol the reciever now' button? I assume you push a button to switch which device the remote will control, and then push another button to astually have the device do something
Mar 09, 2013 | Sony STR-DE875 Receiver
Sony reciever shows protect on display
May be bad connections on the preamp ic's. Otherwise there is a short in the amp that needs to be repaired.
Jan 02, 2013 | Sony Str-d350z, Av Am/fm Reciever, Home...
Universal remote programming code for str de697 reciever I am trying to program my ATT uverse remote to operate this reciever.
Here are the list of Sony remote codes :
5017, 5023, 5028, 5029, 5030, 5031, 5032, 5033, 5095, 5096, 5097, 5113, 5117, 5121, 5125, 5129, 5133, 5134, 5136, 5146, 5162, 5163, 5169, 5170, 5171, 5172
Here is how to program the remote.
  1. Turn on the Receiver.
  2. Press and hold AUX and OK at the same time.
  3. Release both the AUX key and the OK key at the same time. All the Mode keys should flash twice.
  4. Enter the four digit setup code and the AUX key will flash three times indicating correct entry and return to normal operation.
  5. Point the remote at the Receiver and press the power button. If it turns off the receiver it is now programmed. If not Repeat steps 2-5 until the remote turns off the unit.
Good Luck,
Robert
Feb 27, 2011 | Sony STR-DE697 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
No Center Channel on STR-DA5200ES
Da 5200es. Workiig only two Chanel i need five chanel. ihave no remot
Aug 04, 2009 | Sony STR-DA5200ES Receiver
Sony STR-VX550 does not obey remote commands from "optional" Sony RM-S750 remote commander. RM-S750 is working properly and communicates all commands to my other STR-VX550. Receiver appears to be...
You appear to have reprogrammed your remote. Remotes can work with other units made by the same company. But the keys will pass out different signals to each unit. You need to find the correct code for your unit.
This could involve selecting a combination of keys on the remote and possibly some controls on the unit. Then entering a numbers on the remote.
It could be that the unit has the option of selecting a remote mode 2 also. So you will need to select it back to one or whatever it is supposed to be.
Jul 09, 2017 | Sony Audio Players & Recorders
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
Sony ES Series Home Theater A/V Receiver  STR-DA5400ES 7.1 Channels Logo
192 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
