Question about Sony VAIO PCV-RX511 PC Desktop
Changing Sony Vaio BIOS
I'm unable to change the BIOS so I can boot from the CD or DVD rom drive to install a linux OS. I tried removing the jumper to flash the BIOS, which enables me to restart the computer and change the BIOS, but the settings won't change. When I return to the BIOS the settings are the same. And I cannot access the disk to boot from it and install VectorLinux.
  • Rue Felix Jan 10, 2008
    I'm sorry I should've clarified. When leaving the BIOS, after I've set the master and the slave, and also the boot sequence, I saved the changes first, then exited while saving changes, over and over again, and no dice. Now I've gotten to the point where I believe I'll have to set my cd drive to master and my harddrive to slave to boot, and if that doesn't work I guess I'll just keep trying. I've used other harddrives set to master and the one I'm attempting to format to slave to do it that way, but I get a NTLDR is missing error. Very frustrating. but thanks for your help.
  • ares_766 Sep 18, 2008
    I have a sony vaio laptop and I'm trying to format it. I managed to enter BIOS and I've setted the dvd-ram as primary and tried to install windows but it says I have no hard-disk enabled. How can I install windows and format the hard also?
I couldnt get the boot menu to come up either, so i had to disable the hard drive from booting in the BIOS, so the system had no choice but to boot to the cd-rom. Worked great!
Posted on Apr 13, 2008
  • 56 Answers
You should be able to exit and save changes, which my guess is you are exiting without saving the changes. theres is a way around this, by pressing either F8, F9, F10, or F12 to access the boot menu, and then you can boot from cd to install your linux operating system
Posted on Jan 09, 2008
Use F2
Posted on Mar 01, 2008
  • tongnab
    tongnab Dec 25, 2012
    but,it can not.
I can't change the first booting device as CD drive on my Hp dx220 system, eventhough i have changed in the BIOS it won't boot from CD, automatically it starts from the HDD since the Operating...
You can boot up your laptop with Tenorshare Data Recovery WinPE to recover your files.It allows users to burn ISO file to CD/DVD/USB Flash Drive and boot up Operating System from bootable CD/DVD/USB Flash Drive directly.You can use it to retrieve data under any boot up problem.Get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm Then perform a system restore to fix your operating system.
Aug 03, 2011 | HP Compaq Business Desktop D220
I just assembly desktop with gigabyte motherboard and ADM CPU, RAM etc...after that i install os Window XP in the 500GB hard drive, the installation done successful, but the problem come out after i done...
This is not a hardware problem, it's a BIOS problem and install problem. Here is my suggestion:
1. Go into the BIOS and set your boot as a) CD-ROM/DVD-ROM
b) Hard Drive
[and it does not matter what is next just as long as the first two are as above.]
2. Reinstall windows os, when ask you want to format drive and install. (This will erase EVERYTHING and reformat the drive space.)
3. When the install is finish, REMOVE the Windows disc and reboot the system.
This should solve your problem. Sometimes if a file was not installed correctly and you leave the install disk in, windows will try to reinstall the files and go from bad to worst.
Good Luck
C2Solutions
Feb 08, 2011 | Computers & Internet
I add another dvd rom to my PC but it refuses to load my operating system. my OS is windoow xp celeron iv with 40G hard disk. Desktop computer with 256GHz ram. I eqully returned the rom using corect...
there may be a clash of IRQs of the DVD ROMs....
the 1st DVD ROM has been alotted a IRQ and then you connected the 2nd DVD ROM but the OS does not know which DVD ROM drive to look for while loading the OS to look for the boot CD....based on the setting in BIOS for boot order....
plus you may have to define both the DVD roms as primary and slave by making changes in the jumper cables...
(google and loacte the solution for the jumper setting for that)
reg
May 05, 2010 | Computers & Internet
Getting three beeps with my asus m4a785t-m motherboard initializi
Okay, not much else is mentioned about the system so I would assume you have one CD/DVD drive and now two HDDs and your new HDD is still set to factory default of "Cable Select" or CD, if not and the new hard drive is a replacement for a damaged OS (Operating System) drive, then you need to insert the Windows OS Installation disk prior to booting and set the system to check your CD-ROM before checking Hard disks, for the OS.
First off if IDE, you have a ribbon that resembles this [====[========[ the furthest to the right would be what plugs into you motherboard, being the one with the furthest distance between itself and the next plug/connector.The one on the other end is for the Master drive and teh middle one is for Slave.
If only one HDD, then the jumper for the new drive needs to be set to Master and the CD/DVD-ROM needs to be set to Slave.
  • If two HDDs & one CD/DVD Rom, On the primary IDE Controller, set the OS HDD to Master, the CD/DVD-Rom to Slave & put the second HDD on the secondary IDE Controller as Master.
  • If two HDDs & 2 CD/DVD-Roms they must be set up on totally different IDE controllers to cancel out the chance of cross-communication. This happens on some systems because of having two CD/DVD Roms and/or two IDEs. So, we set the OS HDD to Master on the Primary IDE Controller & we set the CD/DVD-Rom to Master on the second IDE controller and the
I would normally say that three beeps from the motherboard itself would be either graphics card or memory problems, normally solved by simply pulling either or both and reseating them. Wear Nitrile gloves (the blue ones) to keep oils and static charge from damaging the components, ground yourself &/or touch the case before and while pulling the components. Check this site for "Post Codes" if the beeps are coming from the MoBo... if you have Award BIOS (should show what BIOS brand when booting up the system)
Award BIOS Post Codes
If three beeps from the system itself, then that would say it can't find the OS... and you might possibly also find an error on the monitor, stating something similar to "no power to monitor".
If you don't have an illustration on your drive telling you what pins are for what when it comes to the jumper, then search google for the drive brand and the word "jumper" or words "jumper configuration" or "jumper placement"
example: Maxtor Jumper configuration
If the system is SATA only (I believe it to have at least one IDE controller unless the board's controllers are all blue & black, to which I see a controller, but can't tell if it is FDE or IDE), then you'll most likely have to enable the SATA controllers in BIOS and set the boot preference/sequence/order as mentioned above, to check the correct disk for the OS, after removable devices & CD-ROM. Should be that order anyway, with floppy seek disabled to save wear on the head.
Hope that was not too much and that it helps!
Apr 15, 2010 | Frigidaire FEQ1442ES Electric Dryer
Can i boot from usb
I'm sorry but the answer is no.
You only have floppy, hard drive and cd-rom options. With some Dell models the USB is seen as a secondary hard drive from within the BIOS so maybe (if your bios supports it) you can change boot order there.
Usually thats not the case so you mainly have to boot from the CD/DVD to install or run a DOS or linux command.
Regards.
Feb 09, 2010 | Dell Latitude C600 Notebook
I can't install any OS because by DVD drive doesn't detect it!
have you tried using fdisk and delete partion then make new partion and set active partion then boot from CD which will then format drive then install OS
Jun 24, 2009 | Computers & Internet
DELL Demension 8300 PC, cannot boot from cd rom
try ubuntu which is a good version of linux,search on google..Now if you really want to install another o/s then you need to change BIOS setting to boot from cd first on start up screen.For most pcs it;s normally a delete or F2 button but hace a look at boot up it will say something like press del or F2 to change...
Jun 22, 2009 | Computers & Internet
Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
May 28, 2009 | Dell Dimension 8300 PC Desktop
Configuring dell optiplex 755 sff
on the back of each device their should be a jumper on the right side next to where the ribbon cable plugs in. Remove the jumpers and replace them into the slot thats for "Cable Select" Their should be a picture on the top of the device if they aren't labeled. You can also put the jumper for 1 as "Master" and the other as "Slave"
Apr 20, 2009 | Dell 16X DVD±RW Serial ATA Internal Drive...
My pc was doing this but now it's doing something different but simular
Try telling it to boot the CD instead of the disk for now, since you need to install from that...or perhaps a newer OS.
Jun 23, 2008 | E-Machines eMachines T3830 PC Desktop
Sony VAIO PCV-RX511 PC Desktop Logo
5,111 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
