Question about Thule Folding 4 Bike Carrier for 1-1/4" Trailer Hitches - Hitching Post Pro
The trailer ball is rusted into my trailer hitch. Any solutions?
    Scholar:
  • 124 Answers
Soak with WD40 2days tap gently with hammer, if that doesn't work try heating with propane torch and taping again be careful WD40 is flamable! good luck
Posted on Nov 15, 2009
  • 8,404 Answers
Tap with a hammer - a little WD-40 or Liquid Wrench - tap some more.
Good luck with this "sticky" problem.
Thanks for your interest in FixYa.com
please vote
a
What size gooseneck hitch do i buy to pull my 36 ft dutchman colorado fifth wheel
depending on where you buy your hitch, a salesperson versus online. but if you get a chance to stop by a camper place and ask what size they recommend. There are a multitude of sizes and styles. like I have a 1 ton dually with the pin in the bed of the truck while my international 4700 has a small semi style plate with the ball ( kingpin) on the trailer. best to see what they would recommend. no obligation and information is free.
Nov 16, 2015 | 1059 B&W Turnover Ball Gooseneck Hitch...
What size gooseneck hitch do I need to tow my fifth wheel
check with your local trailer shop but I thing that it will be around 65 mm or 2 1/2 " ball
it is bigger than the standard 2' ball for normal bar hitch
they come is two forms
one is a mini version of a heavy vehicle turn table and the other is a large version of a ball that is locked in place when coupled
it will depend on the type you have
but talk with a trailer shop to get the regulatory size for what you are towing
Nov 16, 2015 | Cars & Trucks
I just bought a horse trailer and when I hook it up to my 2006 Silverado, the lights don't work. My trailer hitch and wiring system are new, and the previous trailer owner tested the lighting of
Some people wire trailer plugs differently. If the plug is not wired differently than yours, make sure the tow ball is clean. No rust. That's where the trailer gets its ground from. Usually they will work if thats the case, but not right. I can't remember what the wire colors are right now. Go to etrailer and look up the diagram.
Feb 05, 2013 | 2006 Chevrolet Silverado
What size ball does it take to pull trailer
the hitch vin located at the front usually has those specs. 2 inch is most common for trailer balls. most hitches unbolt from trailer you can remove it and take it to an auto zone or such a parts house to match it up. they are usually held together with 3 bolts
Oct 21, 2012 | Brinkmann Roadmaster 855-4524-0 All-in-One...
Grand cherokee knocking from rear when towing
possible that the ball size is wrong for the tow hitches
they do come in two sizes and there is just enough difference to allow movement at the ball
Apr 20, 2017 | Jeep Grand Cherokee Cars & Trucks
I have an 03 Toyota Sequoia, 4.7L V8, factory installed hitch receiver and wiring. The manual says it has a towing capacity of 6500 lbs GVWR. I have been towing a popup trailer weighing 3000 pounds with no...
I think the tongue weight rating on the stock hitch is 600 lbs, so you are over that. You probably want to level out truck to handle better when towing, so the best way is to get air bag helper that raises the back end.
Sep 20, 2010 | Cars & Trucks
My trailer brakes do not work when the ball and trailer make a connection. But if I just plug in the trailer to the truck I can hear them working. I have checked everything and have had others look at...
Both the ball and the trailer hitch should be grounds so I'm guessing the trailer brakes have a hot wire touching the frame somewhere but not enough to blow a fuse. Before connecting the hitch to the ball, have someone press the trailer brakes and check between the hitch and the ball with a volt meter for 12 volts. If you do then something is wrong with the trailer brakes. I'm just guessing though.
May 17, 2010 | Cars & Trucks
Do the 2009 Nissan Frontiers have a turn signal flasher? I had a 2'' ball hitch installed and when attaching the boat trailer to the hitch the trailer turn signals don't work. When they hooked up the boat...
check for signal ground,this is not a metal ground, use a test light or volt meter to see if they at plug before you plug in the trailer, you may need to rewire the trailer.
Mar 19, 2010 | 2008 Nissan Frontier
Thumping noise while towing
first thing to mind is that the tow ball and the tow hitch are not the same size and the hitch is loose on the ball
If you are using and older style ball on a late model caravan that is a very definite possibility
Feb 09, 2018 | 2001 Nissan Pathfinder
How do you easily get a bolt into a rusted thread?
new bolt? or remove the rust on both my soaking in vinegar or a commercial solvent.
Mar 31, 2009 | Thule Folding 4 Bike Carrier for 1-1/4"...
Thule Folding 4 Bike Carrier for 1-1/4" Trailer Hitches -  Hitching Post Pro Logo
336 people viewed this question
Top Thule Cycling Experts
Michial Gueffroy
tau1618
Are you a Thule Cycling Expert? Answer questions, earn points and help others
