Question about AT&T LG CU515 Cell Phone - Black
When It turn on its stuck of at&t part for 2 mintues it ask me error fatal file: dog: startu line: 0 hold 7 to enter dload mode usb hold * key to reset & log abort memory upload. abort. log will be saved in /err folder after reset. Do I need a new phone or not
My note 4 is stuck in dload mode and i cant enter rcvry mode. Wheinstalling firmware i accidentally checked the repartition box. How can i restore my phone reactivation lock somehow got turned on
If u need to go to recovery, restart phone then hold up vol and home button together.
If its stuck on download mode, use odin (latest) to flash stock firmware and also u need to have pit files. Search XDA Developers for files you need.
Mar 15, 2016 | Cell Phones
Model 233. What does error code C440 indicate?
C440 error indicates a fuser temp too high or too low. SOMETIMES it's random and can be reset by 1. hold down the 0 and 8 keys while turning on power. 2. Enter 400 press Start. 3. Enter 0 press Set or enter. Copier will begin warm up mode. If the code recurs, you will need the fuser unit rebuilt or replaced.
Oct 04, 2015 | Toshiba Office Equipment & Supplies
Just bought Brother Printer dcp-j125,After test copy machine says,machine error af. Removed elec cable,plugged back in ,held menu for 15secs.. machine error af,came back on..it makes a funny noise.
Brother DCVP-J125 manual reset
1.plug the power cord while holding the menu with in 16 seconnds to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. press the mono start key several times untill the purge count appears on the LCD.
4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. press the stop/exit key to return to the initial stage of the maintanance mode.
6. enter 9 twice by using the up arrow & set key's to exit from maintenance mode
just follow the steps and hope you can do it......
I try it to my self before i post it and shared to others....thnx and GOD BLESS by Harry Technician.
Mar 12, 2011 | Brother MFC 420CN All-In-One InkJet...
Fatal error 428056ec + 4280999c
Hello.
Try resetting the printer:
  1. Power on printer while holding both the "+" & "-" buttons simultaneously; release when "OKIUSER" is displayed.
  2. Press either the "+" or "-" button until "ENGINE DIAG MODE" is displayed; press "Enter" and "DIAGNOSTIC MODE xx.xx.xx" will be displayed.
  3. Press and hold both the "-" & "On-line" buttons simultaneously until "ENG DIAG LEVEL2" is displayed.
  4. Press either the "+" or "-" button until "CONSUMABLE COUNTER SET" is displayed, press "Enter" to go in the menu to set various consumables.
  5. Press either the "+" or "-" buttons to go to the desired consumable and press "Enter": the last digit of the count will start flashing.
  6. Press "Cancel" to decrease the digit amount or press the "On-line" button to increase the digit amount; press the "+" or "-" buttons to move along individual digits in the count.
  7. Once the count is at the level you desire, press and hold the "On-line", "Cancel", and "Back" buttons simultaneously until the "*" reappears next to the count; consumable's count has been reseted to the number specified.
  8. Press the "+" or "-" buttons to move to the next consumable and repeat at step 5.
  9. Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, use the "Back", "+", and "-" buttons to exit through the menus (reverse of steps 2 through 4) until "INITIALIZING" is displayed.
  10. Turn off the printer and turn on.
Hope this helps.
Nov 08, 2010 | OKI C5400 Laser Printer
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
MadDog MD-16XDVD9 could not perform end of disc-at-once
Have you tried checking your basics ?
Firmware ?
ASPI ?
Disk Defrag ?
IDE location ?
Jumper settings ?
What type of media are you using ?
What programs are you using ?
Exactly where are you and what are you doing when your error occurs.
What are your PC's specs ?
Do you have any Roxio products installed on your PC ?
Please answer ALL of the above - if you don't know, say so, don't make something
Oct 20, 2009 | Computers & Internet
C470
this is a fuser unit error code. reset code in following way.
1, turn off power. 2, hold down 0 & 8 keys. 3, turn on power still holding keys down until beep is heard. 4, enter 400 on numeric keypad. 5,press start button. 6,enter 0 on numeric keypad. 7,press enter icon on the main lcd display.8,cycle power
Oct 05, 2009 | Toshiba e-Studio 350 Copier
161 fatal error C7300
Try this - WARNING - will reset everything to factory defaults
The machine must be put back into "Shipping Mode" in order for the consumable counters to reset.
In order to place the printer back in "Shipping Mode" do the following:
0.27c?openelement&fieldelemformat=gif
1. For the C72/74/92/94 models, hold the (1) and (5) keys down, for the C73/75/93/95 hold (0), (1), (6), and (7), while turning the printer power on. (Hold until "MAINTENANCE MODE" is displayed)
2. Press (0) five times until "ENGINE DIAG MODE XX.XX" is displayed.
3. Press the (2) and (4) keys simutaneously, "ENGINE DIAG LEVEL 3" should now be displayed.
4. Press the (5) key once, "LOCAL PARAMETER SET" should now appear on the display.
5. Press the (6) key three times until "FACTORY WORKING MODE" is displayed.
6. Once "FACTORY WORKING MODE" is displayed, press (3) once so "Shipping Mode" (Fuse Cut Enabled) is displayed in the bottom line.
7. Next press and hold (3) & (7) together, until "Shipping Mode" stops flashing.
8. Power the printer off and back on, now the printer will reset the consumable counters. ecblank.gif ecblank.gif ecblank.gif
Aug 30, 2008 | OKI C5300n Led Printer
Enter usb 2.0 mode
I don't know steevil? I've been on the phone for hours with sandisk support. I'm getting the same message but I thing my resolution is returning my Sandisk e280r mp3 player and trying a different brand. Good Luck. I'll write again if Sandisk has any more solutions.
Dec 26, 2006 | SanDisk Sansa e260 MP3 Player
AT&T LG CU515 Cell Phone - Black Logo
151 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
