Horn doesn't work horn wired direct works. fuse ok.
  • 54 Answers
Check the horn relay.bobg22
Posted on Nov 15, 2009
2004 pontiac montana horn doesn't work. Fuse is OK and Relay is OK. What could be the cause?
The horn itself may be faulty, disconnect it and use a voltmeter to see if the voltage changes on the wires feeding it when someone presses the horn button. Most horns are 12V so you should also be able to connect the horn directly to the battery to see if it works. Just get the polarity correct.
The horn switch harness. (the switches and wiring in the steering wheel) Disconnect the negative battery connection before attempting to check this as the air bag is also in that area.
Nov 21, 2016 | 2004 Pontiac Montana
HORN NOT WORKING
There is usually only 1 wire to the horn from the steering column, via a relay. Disconnect this wire and run a bit of wire from the positive terminal of the battery direct to where you took the wire off. The horn should sound. If it does, then you know the horn is ok and the fault is probably the relay , broken wire, blown fuse or poor connection in the horn circuit. If the horn doesn't work, then you know that the horn itself has failed.
Apr 12, 2015 | Cars & Trucks
Horn is ok but not working
Just curious - how can the horn be OK if it doesn't work?
Of course, horns do fail, their wiring and/or fuse can fail and the switching mechanism can fail.
Put your DC meter on the horn terminals and attempt to blow the horn - if you measure 12vdc, replace the horn. If no 12vdc, you have either a failed horn switch or a wiring fault.
Mar 23, 2014 | 2005 Toyota Corolla
Corvette horn not working
I have a 1999 corvette and the horn will not blow when pushing on the horn pad. It beeps when locking the car and security system.how do I locate the problem. Thanks Bob
Jul 12, 2012 | 1986 Chevrolet Corvette
1988 ford broncho horn doesn't work ,relay clicks when horn button is pushed,I replaced the horn it still doesn't work. what should I check next.
OK, try to use a test light and connect the horn lead to ground to see if there is current, and to see if it sounds. If it does, then the wiring is fine to the horn itself. The relay may click, but are the contacts ok? Maybe swap out the relay for a new one.
Nov 04, 2011 | Cars & Trucks
Horn doesn't work, relay is OK
hi,
there are two powers go to your relay.first is coming from your horn button to activate the relay coil when another from fuse. if both power alright then you need to check wiring and horn itself. regards
Sep 27, 2011 | 2003 Oldsmobile Alero
Horn won't honk on my 2004 Buick Rainier
check the fuse; the fuse box it's located under the dash on the left of the foot rest (drivers side)
Jul 05, 2011 | 2004 Buick Rainier
Horn doesn't work
check fuses
if they check out ok
find the horn sometimes they hide them pretty good once u find the horn unplug wires from it and take a jumper wire and hook battery directly to battery if horn doesnt work u have bad horn
if horn works u have a bad wire or bad horn button
Apr 07, 2010 | 2001 Toyota Corolla
2003 gmc 2500 hd..horn doesn't work
The horn pad is made of vinyl which contracts through the four seasons causing this problem for some. Remove the horn pad with the battery disconnected first of all. Use a jumper wire to see if the horn works. If id does check the horn relay next. If ok hot wire the horn direct. One should be your problem or it is a broken wire instead
Apr 04, 2010 | 2003 GMC Sierra 2500HD
27 people viewed this question
jasbo
jasbo
