Re: The timer light on my tv keeps flashing and we are...
The V26 Chassis DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacment capacitors and the CD with detailed repair instructions
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Or
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
I'm having same issue with same TV. It powers off after about an hour and red power light starts flashing. Only way to power back on is by unplugging TV and waiting a while, then plugging it back in, but then the TV will turn off again after a few more minutes, red light flashing again. I've checked the sleep timer and it is turned off, so any other solutions to this problem? All capacitors on power board look fine (not blown). I've read it could be solder joints in power board need to be resoldered.
Please update this with the blink count. That will indicate the circuit in which a problem was found. Once I have that information I should be able to give you the probable cause and remedy.
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes. help! trinitron kv29f1u only clicks and blinks
