Question about Maytag PYE2300AY Electric Dryer
Felt / material that drum rides on front and back? had that material melt and start fire in vent, do these need to be replaced after so many years . material was leaning againts heating element and over temp sensor.
  • Maytag Master
  • 8,404 Answers
You saw what you saw ... I would suggest it was probably lint that caught fire not the felt. In my experience the felt 'bearing' will last the lifetime of the machine though that is not to say they will not wear out earlier than that. They are normally replacable so obviously, someone thinks they wear out and yours may well be among them. I would also normally expect any lint or felt parts to be drawn into the lint filter not toward the heating element.
What should happen is the fan should be pulling air out of the drum (and exhausting it out of doors) via the lint filter which in turn draws fresh room temp air over the heater element and into the drum to dry the clothing in the drum to be pulled through the lint filter and into the fan and to the out of doors, repeat.
I don't know if these remarks are making any sense or not to your situation. I'm glad you are here to ask the question - apparently the fire was contained at some level.
May I suggest that if you have not already, use hard metal pipe for your exhaust or, at a minimum, flexible metal pipe. It is also important to clean this exhaust from time to time.
Thank you for your interest in Fix.Ya.com
Please vote
thanks
a
Posted on Nov 15, 2009
  • Maytag Master
  • 7,482 Answers
The felt material you talk about is probably the front felt seal. It goes between the front of the machine and the drum. Normally these seals last for quite a few years, but they do go bad after a while. This can be caused by normal wear, and also can be caused by wear in the drum rollers.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum,front felt seal and belt. You can stop there, but I would recommend that you follow thru and do the following:
Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
How to repair stainless steel on a dryer drum
For my Frigidaire manufactured Kenmore dryer, the stainless steel drum is part ordinary painted steel (front flange). That flange is part of the suspension for the drum. The flange rides on a nylon wear pad above the door. On both sides of the pad, there is a felt that is glued to the dryer front panel to act as a seal. What happens is that the paint on the ordinary steel flange rubs through and rusts, staining clothes during the drying cycle. I have to replace the nylon pad and felts every few years to combat the rusting issue. The felt and nylong pad assembly is glued to the cabinet flange using heat resistant adhesive.
Feb 25, 2012 | Dryers
Extremely screeching noise when running?
Screeching is the metal-on-metal contact of the drum touching the rear of the unit while
turning - there's a (usually) felt cover gasket over the circular depression at the back of the dryer.
When this wears through (after a number of years/loads), you get the screeching of
metal-to-metal contact.
Problem: friction can heat up the metal so much that the remaining felt gasket material (and/or
accumulated lint or clothing) catches fire.
Fix: replace felt drum gasket.
The Maytag Atlantis MDE6400AY electric dryer has a DuraCushion(tm) dryer drum, so I'm
suspecting the "DuraCushion" has worn out at least at one point in its 360-degree arc.
Jul 07, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
My dryer eats my clothes by twisting them up between the drum and door. is there an update to fix this?
the front of the drum rides on a felt pad. as the pad wears down it creates a gap for the clothes to get caught in. you just need to replace this felt. sometimes called front bearing sometimes called felt seal.
Jun 26, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer drum is scraping something and black deposits are turning up on our clothes
Well there are two parts to the drum, there is the bearing in the back and the felt pads in the front which the drum rides on. There is also a belt, but if something is scraping it would not be that. Is sounds as though the cover on the felts has worn off and your getting felt material on your clothes, so those need to be replaced. You need to get the proper felts for your dryer than you need to look for any screws on your dryer casing that will allow you to remove the casing and get to the drum, as the pads are underneath the drum. (Note: Inside the door there may be screws on the underside of the upper deck, and the deck should tilt backward on hinges)
May 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Getting some sort of rust stain on my clothes from this dryer?
if you look inside b/w the drum to the front wall you see on the bottom a gap.
this gap come from ware and taire of the seal felt. and the clothes get stuck there. you need a new upper felt (its like special sponge or fabric)
as a technitian i change thus every 4-5 years b/c they just ware down .
the felt is the sponge that the drum ride on ,in the front wall of your dryer
May 01, 2010 | GE DVLR223 Dryers
Drum is loose front to back and makes noise when drying. This is a new noise. Dryer is 3 years old, moderate use.
there is a thimble on the back of the dryer it acts as the bearing it is made out of some kind of fire retardant material see if it is bad .my dryer hit the front face of the dryer and the guide has worn forward there is also a felt pad around half of the bottom on the front of the drum it is pretty tricky to get apart but you can replace every part on the front just way out the cost
Jan 27, 2010 | LG DLE2512W Electric Dryer
My dryer makes a scraping noise when the bowl
You may have two problems:
1...The felt seal around the door is faulty,broken, or out of place.This will cause the problem of zippers,buttons, etc. to get caught between the door and the drum
2...Drum rollers, this causes squeaks,and thump type of noises.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication and the felt seal between the door and drum maybe faulty.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt,and felt seal.
Check your felt seal at this time to see if you can reinstall it or you may have to replace it.
Remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise and the problem of getting clothes caught in between the door and drum.
Good Luck,
I hope this helps
Oct 29, 2009 | Frigidaire Dryers
Frigidaire crown series dryer
The back of the drum has a hub (a flat steel piece with a shaft and ball) which allows the drum to turn. That ball rides in a plastic "cradle". Unfortunately on the crown series...if the ball and cradle are not greased regularly, the plastic wears. This allows the drum to "sag". The front end of the drum is lower than the back. You can confirm this by running your finger around the front of the drum. You'll notice that the top of the drum is almost flush with the body of the dryer and the bottom of the drum is 3/4 of an inch lower that the the body. This allows clothes to slip into the gap at the bottom and then they are spen to the top pof the drum were the lodge between the body and the top of the drum. The turning drum burns the clothing. Replace the plastic piece that the hub rides in.
Dec 28, 2007 | Washing Machines
Sears Dryer 417.80042990
What is happening here, is that the front bering (the area between the front and the drum) has become worn. Its not a very expensive or time consuming job really. Remove the top, then remove the front. You will tilt down the front and door assembly. Dont worry about the drum falling out, Frigidaire uses a ball and hitch rear bering that will hold it in place. On the very top of the door opening indise the front cover (where the drum rides on that felt) you should see a felt like covering with like 4 or 5 plastic type drum glides. Replace the top half of this felt with those plastic glides attached (should be attached). Just re-glue the felt to the drum (glue should come with part, and watch it, this glue is for real if you get it on you). If you wanted to be a real explorer, its always a good idea the lube or grease the rear bering of these Frigidaire's while your this far into it. If you want to, just remove the belt (remembering how it went back on the idler pully), then, with two towels around your hands, grasp the drum at around the 10 o'clock position and tug upwards to remove the drum from the rear bering. Also be sure to remove the drum upper support (yellow looking clip thing front center that will hold the drum until you remove it). Use a good quality-high temp grease inside the bering and the ball on the back of the drum. This will ensure you wont have to go back in there again normally for the rest of your dryers lifetime. Enclosed a picture of the front bering glides and felt:
And a small break down of the front section. Your part will be #20 that you will be replacing.
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=0582&modelDesc=DRYER&modelNumber=41780042990&documentID=P0010402&documentTypeID=PLDM&documentClassCode=PM&titleType=DOOR&titleID=00002&
Let me know if you need any further assistance or have any other concerns or needs. Good Luck!!!! Jim
Dec 06, 2007 | Frigidaire FEQ332E Electric Dryer
Dryer marks clothes
it could be the adhesive that holds the felt bearings on the front housing. you see the back of the dryer drum has a bearing in its center, the front of the drum rotates on two or more felt pads or bearings in/on the front cover where your door is. you'll need to remove the front cover to replace these felt bearings. there should be two screws, maybe more holding the front cabinet to the rest of the dryer. the bearings will be mounted to the front cabinet right around the hole for the door.
Aug 09, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Maytag PYE2300AY Electric Dryer Logo
128 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
