Question about Campbell Hausfeld 28 - Gallon Air Compressor
Oil blowing out of the air line
I have oil blowing out of the air line . It still pumps up air but blows oil. what is wrong?
    President:
  • 1,167 Answers
Thats your piston rings gone buddy thats all it can be
Posted on Nov 16, 2009
Chain oilpump clogged
You haven't stated the make and model, but it's a relatively simple process to access the oil pump and blow out with an air-line. Also make sure your oil tank is empty, remove the oil cap and blow through the main oil line back into the tank.. This can then be flushed out.
May 10, 2016 | Garden
Rear air suspension doesn't inflate everytime vehicle is started
My Buick had this problem and we found the pump was worn out. It just would not blow up when trying to run. They wanted a lot of money to replace it and the shocks.so I bought a kit that the air line hooks underneath the license plate Now about once every three months I use my air compressor to pump it up. My old air shocks lost air all the time. My new air shocks stay blowed up for over three months.
May 31, 2017 | Lincoln Navigator Cars & Trucks
2001 aztec, new thermostat...over heats in winter, and when speed reduced blows cold air. Plenty of antifreeze. Any ideas what could be wrong?
YOU HAVE TO BLEED THE LINES THE ARE TWO NIPPLES ONE BY THE THERMOSTAT AND ONE BY THE WATER PUMP. YOU HAVE AIR IN THE LINES THE AIR BUBBLES BUILD UP IN FRONT OF THE THERMOSTAT AND PREVENT IT FROM ORENING ANY TIME YOU OPEN THE RADIATOR CAP OR ANYTHIN YOU MUST BLRRD THEM LINES YOU MIGHT HAVE TO DO IT A COUPLE TIMES BUT A RELATIVELY EASY FIX
Dec 26, 2011 | 2002 Pontiac Aztek
Gardner denver air compressor is blowing oil, need help
Is this a rotary screw compressor? If so, is it blowing oil out of the air filter or out of the discharge air lines? If it's blowing oil out of the air filter you have a oil stop valve or minimum pressure check valve bad. If oil is coming out of the discharge air you need to change the seperator.
Nov 15, 2010 | Air Tools & Compressors
Motor runs blower seems to be blowing air can get flow out bleed on pump tried two different pumps both plastic couplers between end of motor shaft and pump are good No flow out of either pump, even when...
Are you referring to an oil pump? If you get oil out of the bleeder screw but not out of the jet valve (small copper line going to nozzle assembly), the strainer in the pump could be blocked. Hard to believe both pumps could have same issue. Pull off end of oil pump and inspect strainer. Is there a by-pass plug installed in it? Remove it if so.
Dec 20, 2009 | Heating & Cooling
I have a Aprilia rs 125 2008,done 4000ks. It blows too much smoke
maybe rings are you losing coolant check the spark plug if it comes out with oil or too wet this means your oil pump is pulling to much in get back to me budd
Sep 10, 2009 | 2000 Aprilia RS 125
2004 ford diesel blows white smoke. and drops of
look for block return lines- air leak in suction lines -block fuel line or filter - defective injection pump -inoperative glow plugs.
Jul 04, 2009 | 2006 Ford F-250 Super Duty
No auto lube to chain
If the filter is intact, then the dirt was in the line to begin with. Disconnect the inlet line at the pump and blow out the line with compressed air (from the tank side). You might clean the oil tank while you are at it. The blow-out is unnecessary if replacing the above parts. Put some oil into the new pump to prime it. Don't try to fix the damaged plastic gear.
Jul 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Husqvarna 136 is not getting enough oil. Changed the pump, but it is not drawing it up to the bar
what you can do is try taking the cap off of oil tank drain oil, take chain & bar off try taking compreesed air or air blow nosel in hole going to blow & if its clogged it should blow out of cap hole or there might be a hole in line but it might have saw dust in oil clogging oil from coming out
May 22, 2009 | Heavy Machinery
Oil blow out the breather
This is a common problem on all sportsters, they have an oil blow by that dumps it into the air filter. I have found that if I run about a half quart low the problem goes away.
Nov 10, 2008 | 2000 Harley Davidson XL 1200 C Sportster...
Campbell Hausfeld 28 - Gallon  Air Compressor Logo
207 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
