Question about Palm Tungsten E2 Handheld
My Palm Tungsten E2 does not turn on.
It suddenly stopped turning on. It does not respond to my pressing any of the buttons. I did charge the device using the charger and the sync wire. I have some information on the Palm that I need to retrieve and save so I do not wish to hard reset.
In the past, it did behave similarly. The screen would remain lit, and not responding to any buttons until the battery died and then the Palm would work normally after charging. But this time the screen remains off. I suppose if we could drain or disconnect the battery, the Palm would work normally after the battery is reconnected. My Email address is p.bral@yahoo.com, Phone # 201-264-4862.
  • 28 more comments
  • Bral Jan 09, 2008
    Thanks for the comment. Yes I have tried a soft reset. But it did not help.
  • Anonymous Mar 11, 2014
    the gear shift moves and it goes in reverse and moves and drive it moves just doen't shift after drive
    We need a drive motor for capresso c1000. A piece broke off.
    Repair hood release 2009 jeep patriot
    where is the pcv valve on a 2002 cadillac deville
    Timing marks on xv250 Yamaha 1989
    I HAVE A SHARP AQUOS MODEL LC-46D64U IT WONT COME ON THE POWER BLINKS TWICE AND THE OPC LIGHT BLINKS THREE TIMES KEEP BLINKING WONT TURN OFF OR ON HOW CAN I FIX THIS AND HOW MUCH IS IT COST
    PCM reflash necessary
    singer curvy 8763 looper
    how to solve e000002 error canon ir 2520
    matchmaking difficult
    I want to log in to my account
    Every time I drive my jeep as soon as I come to a stop it will start trembling and if I put it on neutral gear it will stop . When driving it it won't do it , it only does it when stoping at at red lights .
    1990 Honda Accord brake fluid reservoir is empty over night help
    alter angle of timebeam as plinth is partially blocking it
    Toilet keeps leaking from the tank to the bowl. Had numerous plumbers here to fix it, and they've replaced all internal parts several times and repeatedly replace the flapper (this one supposedly is the right size)...now what? Replace the whole toilet and start new or look someone place else for a leak besides the flapper? Help--might water bill is $100 when it was $50! Color drops in the tank indicate the leak down into the bowl.
    Porsche boxster instrument cluster stays illuminated
    How to install Infant cat seat in 97 Toyota rav4
    passenger side axle
    check engine light on
    when setting up a booklet in word 2010, the pages are in the correct order, however, when I print the booklet on my officejet pro, they are in a completely different order - very random order.
    1997 Cadillac Seville northstar keeps overheating. plenty of coolant/antifreeze, turn the heat hi on vent, blows cold air and continues to overheat. started overheating bad one day, I shut it off, wouldn't start. had a friend come jump it, it started but then there was a loud POP! ......
    value for 1988 cutlass 442
    Small nape should automatically closed
    How I can reset my voices message's
    Ac light is flashing and blowing hot. Air
    Ca n't download without message coming up and taking me back go home screen
    looses power whenever idling and almost stalls out, brought it in to 2 Ford dealerships and they say there is no problem
    Need manual
  • Anonymous Mar 12, 2014
    I have a restricted water inlet valve in my potscrubber 600, what should I do
    Scholar:
  • 135 Answers
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Posted on Jan 09, 2008
  • Yonatan Horan Jan 09, 2008
    Please note, unlike a hard reset, DO NOT HOLD THE POWER BUTTON. I'm sorry to use caps lock but this needs to stand out so you don't accidentally do what you set out not to do.
    Did you synchronize the tungsten right before it stopped working? If so, is there any data that's only on the device and not on the computer?
    If you disconnect the battery or drain it completely, it could result in you losing the information just like if you did a hard reset. If you have to get the data, you could probably bring it in to a repair shop who will make a copy of everything you have on it, then allowing you to do a hard reset and fix the device.
My Palm Tungsten E2 Handheld won't turn on
try to push the reset button (small hole) on the back of the device. You may need to perform a Hard Reset (returns device to factory settings).
Mar 01, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Palm tungsten E2
Does anything happen when you try to turn it on? Does anything respond or light up?
Jan 19, 2008 | Palm Tungsten E2 Handheld
Tungsten E2 has lit screen & not responding
You can take the back off and unplug the battery for a few mins, this sometimes will clear a logic lock
Feb 27, 2009 | Palm Tungsten E2 Handheld
Tungsten E2 wont power on
Turn it on pressing the reset at the same time or take out battery and unplug/plug the battery. Your battery may have died. If this is helpful, post as such. If it is a fixya, post as such. I had an E2, can tell you alot about it. TY
Jan 23, 2009 | Palm Tungsten E2 Handheld
After turning device on, not respond at all, after reseted.
Upon doing a hard reset, which I assume you did, try this
Palmpowerups.com
PowerDiGi
$18.00
Jan 05, 2009 | Palm Tungsten E2 Handheld
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
Palm will not turn on
have you tried a hard reset?
Todo a hard reset, First press and hold the power button, while holding the power button use the tip of the stylus to gently press and release the reset button. wait for the logo to appear then release the power button.
when you see the message that warns you about erasing all of the info on your hand held press up on the 5way navigator to finish the reset
Dec 21, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2, hangs while resetting
Press the power button while pushing in the soft reset on the back.
Jul 01, 2008 | Palm Tungsten E2 Handheld
Urgent response needed
1 press and hold the power button
2 while holding the power button, use the stylus to press the rest button on the back
3 wait for the "palm powered" logo to appear and then release the power button
4 when you see the warning message
either press "UP" on the 5 way navigator to reset
or
press any other button to do a soft reset
Best of luck
Jun 10, 2008 | Palm Tungsten E2 Handheld
Palm power
Other than pressing the power button, the device will turn on if one of the four buttons on the face of the device are pressed (calendar, notes, task list, etc). So check to see if they might be getting pressed by accident. Unless it is protected by a hard cover, it is possible that a button is being pressed by accident in your pocket, backpack, suitcase or wherever you carry it.
Let me know if that helps.
PS - The device will also turn on if a reminder or alarm is set.
Mar 18, 2007 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
106 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
