Question about Toshiba Satellite 1410-S173 Notebook
Wont turn on... No battery... But when plugged in it will turn on... When the DVD drive is open it will power up... But when i have the DVD rom closed it shuts off instanlty
    Sergeant:
    Champion:
  • 215 Answers
Take it to an expert could be a hardwre issue
Posted on Nov 15, 2009
  • 32 Answers
MY gUESS?
Power Supply Problem
Run Diagnostics.
My dell 170L with IDE h/drive & cd rom wont recognise a sata dvd rom ( connected to sata port & power)
Check that jumper settings are done correctly, also check how devices are shown in BIOS.
Sep 14, 2012 | Dell Dimension XPS 400 PC Desktop
Cd rom wont open
Hi in front of the CD-ROM drive there should be a small pin size hole. Stick a pin in there to release the CD-ROM lock and it should open.
Jun 12, 2012 | Toshiba Samsung Slot Loading DVD+RW Slim...
Change my gx620 motherboard with ide connector for dvd rom to a 745 motherboard which has sata connection for dvd rom so i purchased a sata dvd rom and sata cable plugged everything in but the dvd rom wont...
With sata there are two cables, just like ide. One is the power and the other is for data. The data cable goes from the device to the motherboard. The power comes from the power supply. If your power supply does not have a sata connection you can purchase an adapter that will turn an available 4pin Molex into a sata connection.
http://www.ebay.com/sch/i.html?_nkw=ide+to+sata+adapter&_sacat=3667&_odkw=ide+to+sata+adapter&_osacat=42017&_trksid=p3286.c0.m270.l1313
Sep 11, 2011 | DELL 8X Serial ATA Slimline DVD-ROM Drive...
My Toshiba Satellite 1805-S204 turns off when i'm trying to open DVD-ROM bay. Sometimes i can open it but than notebook turns off when i'm closing DVD-ROM bay. I want to disassemble 1805-S204 to find out...
I suspect, if you haven't got it working on the AC adaptor when this happens, that maybe the battery is low power. If it does it when the AC adaptor is being used then I think you are right, the DVD ROM is faulty.
Remove the battery and AC adaptor.
Remove the Memory cover.
There is a singel screw that holds the DVD drive bay in. Remove the screw and pull the drive out.
Replace the drive with and IDENTICAL model and that should be that.
Hope this helps.
Nov 06, 2010 | Toshiba Satellite 1805-S204 Notebook
New computer tower motherboard(Intel D945GCPE), Processor(Intel Celeron 430 LGA775), memory, hard-drive(ATA), & dvd-rom(ATA). Got it all installed in new tower(ATX,I have green light on the motherboard...
First try to clear CMOS
Turn off the system and disconnect power cables
Locate the CMOS battery on the motherboard and take out the battery
Wait for about 15 minutes
Reconnect battery and try to turn it on.
If it remain same, disconnect power cables
Disconnect hard drive and CD/DVD drives
Try to turn on again.
Also check if the front panel connectors (Power SW, Reset, HDD connector) are properly connected.
Mar 09, 2010 | Intel Computers & Internet
Powers on wont post but dvd rom
Eject any disk from the DVD device.
Turn the computer off.
Disconnect the "data" and/or the "power" connectors from the DVD-ROM.
Turn the computer on, and see if it starts when the DVD-ROM is not part of your system.
If it starts, then your DVD-ROM needs to be replaced.
Dec 08, 2009 | Medion Computers & Internet
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Installing a new DVD drive
Step1::Ground yourself by first touching a metal object or wearing an anti-static wrist strap. This helps protect your computer's internal
components from damage due to static.
Step2::Shut down your computer and unplug it to protect yourself from electric shock.
Step3::Open your computer's case using the door on the side or follow the manufacturer's directions for your desktop.
Step4::Install the DVD ROM on its own IDE channel. Since a DVD ROM uses a good bit of memory, it should also be the master drive. Set your old
CD ROM or secondary DVD ROM drive to "slave" and set the new DVD rom drive to "master."
Step5::Slide the new DVD ROM in the free 5 1/4-inch bay and use clips or screw into place if necessary, then use the data cable that came with
the DVD drive to connect your new drive. Plug in the power cable as well.
Step6::Replace the cover on your computer, plug it back in and boot it up. If you have Windows XP, it should automatically detect and attempt
to install the new DVD ROM drive. If it doesn't, use the installation disk that came with your DVD ROM.
Nov 27, 2008 | Acer Computers & Internet
Dvd rom wont open or turn on
Get yourself a paper clip. Straighten it out. There is a small hole on the DVD ROM drive. Stick the straight end of the paperclip in the hole and it will click a release button and your DVD ROM door will slide out.
Don't forget to rate this with 4 stars before you log out.
Nov 26, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite 1410-S173 Notebook Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
