Question about Panasonic DVD-F65 Multi-disc DVD Player
Color issues Hello! We were watching a dvd last night and all of the people appeared to be in a green tint. What's up? Can this be fixed?
67" Samsung DLP. Last night it started flicker to a green tint. Back to normal then green tint. Now it's completely a green tint. Still has picture and voice but green tint and not bright like before.
In those sets there is what they call color wheel and it could be on its way out it sounds like its stuck.or not working prop in any case you need to bring it in for service place
Mar 26, 2013 | Televison & Video
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
Color problems. last night instantly the color
2 things the cable could be faulty (unlikley)but worth a try
or your lamp is starting to fail
Jun 26, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Red Tint on Screen
This is normal and is a color calibration issue.
For correct color, NEVER use the "WARM" setting. Why? Too red. You cannot get REALISTIC or ACCURATE color using the "Warm" setting.
Since we are speaking of Samsung, first avoid the "Flesh Tone" adjustment. When things are set correctly there is no need for this adjustment. It is a quick fix and not for the "discerning eye".
1. First, access the "Color Temperature" menu. From here select "Cool2" or the coolest temperature setting.
Note: For Samsung use "Cool2", or if not available, "Cool1". Samsung has inadvertently increased calibration confusion by issueing TVs that have just "Cool1", and TVs that have both "Cool1" and "Cool2" :0[
For other brands, use "Cool", or "High", or "+6500k". Anything lower artificially reddens the picture and compromises detail.
2. Now return to the color settings and reduce "Color" to between 30 and 40 (on a 100 scale). The sweet spot is just near the place where the color rapidly washes out.
3. To round out the color palette, move to the "Tint" adjustment and ADD a couple (3-5) clicks to the GREEN.
Adding the touch of green is what is needed to take out the last bit of "pink" and will make all the tones and all colors display properly.
I hope this helps!
To further increase the quality of your picture visit
http://www.wowvision.tv/main.htm
Highdefjeff :0]
Jun 15, 2010 | Samsung LN46C630 TV
The picture has a green tint to it on all channels
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set.
If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Display has a green tint to it tho it looks fine on the laptop.
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loose cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Jan 21, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Nov 20, 2007 | InFocus LP70+ Multimedia Projector
Color problems
It could be, do you have the option to plug in a different item (DVD player) to the same connectors as the cable and see if the color issue exhibits on the DVD signal? If not then you've got an issue with the cable company.
Jun 07, 2007 | Sylvania 6632LG 32 in. LCD HDTV
Green Screen
There are seveal cause to this issue, but with out seeing what your seeing I recommend that you search youtube on this one.
https://www.youtube.com/watch?v=84HPv6Epknc
Mar 05, 2017 | Dell E156FP 15" LCD Monitor
Panasonic DVD-F65 Multi-disc DVD Player Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
