Question about Toshiba 42HM66 42" Projection HDTV
Plugged in our rear projection tv and the picture is orange and green! why
    Genius:
  • Toshiba Master
  • 1,039 Answers
If you are using the color stream input make sure the correct color wires are plugged in the same on both ends. if color is off on all inputs and the TV menu then replace the light engine.
Posted on Dec 05, 2009
  • 13 Answers
SOURCE: Green hue on KP-43Ht20 Sony rear projection tv
Behind the front cover you will see a little plastic box with six phillips headed dials. They only move 180 degrees. The three on the bottom control color richness and the three above them control focus. Turn all three of the bottom ones to the left while the TV is on, then gradually turn them to the right until you get the color you want. NOTE if any one of the three bottom dials are too far up the TV will shut down and will continue to turn off after about 10 seconds after start up until the offending dial is turned back a little.
Posted on Jul 21, 2009
  • 1694 Answers
SOURCE: hitachi rear projection tv. screen looks green
Green CRT bad = take off lower front cover, remove access panel
locate screen / focus block.....turn green screen control slightly
CCW............................re-assemble...........T.
Posted on Dec 21, 2007
SOURCE: philips projection tv
sounds like your cooling fluids in the tubes needs to be changed. Repairman told me it was common on the philips.
Posted on Oct 05, 2008
localwonder
  • 6784 Answers
SOURCE: rear projection tv screen warped
Hi, this TV is repairable and you will have to replace two devices. the first is the Convergence board. this device regulates the convergence of the RGB stream so it can be projected evenly. it works in conjunction with the CRT's and deflection assembly and the Focus pack(module). The second device that will need to be replaced is the Focus pack(module). This module is malfunctioning and is causing the smudges and warped look at this time.
Replace these two devices and it will fix this set. i will post the Part numbers below along with there respective prices as well.
Focus Pack(module).--- Part Number-- BP59-00005A--- $38.95
Convergence Board assembly--Part Number---BP94-00383A---- $165.95
Please rate and god bless:)
Posted on May 07, 2009
  • 42 Answers
SOURCE: LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Posted on Jul 22, 2009
Bad Lamp for TV
Can't get a reception with my ws-a55 tv
Feb 15, 2014 | Mitsubishi WS-55809 55" Rear Projection...
Well hear goes, I have a Philips 60pp9363 60"
Coolant Fluid is a common Problem ,most of the time it will be the Green and Blue Coolant Fuild that becomes dirty and comtainated
With TV on. Look down into each Tube If it is not clear then change the coolant fuild .
Mats Electronics has Coolant Fuild 1-800-628-1118
Oct 29, 2010 | Philips 60PP9363 60" Rear Projection...
Wavy lines green and orange hue.While watching a fooball game the status bar is wavy and in two separate lines-Green and Orange-Tried flash focus and convergence and powered unit off for several minutes...
Flash focus button push,didn't solved pictures convergence problems.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My sony rear projection tv flickers green then shuts down ,any help
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service
Jul 19, 2010 | Sony KP-57WS500 57" Rear Projection...
What does it mean when A PLASMA TV BLINK GREEN AND ORANGE AND HAS NO PICTURE
Tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites liike Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 08, 2010 | Panasonic PT-50LC13 50" Rear Projection...
When turing on tv there no picture but there a green or orange light keep flashing on the button that turn on the t.v
Unplug the TV, wait 5 seconds, then plug it back in and turn it on.
This is a common problem but Panasonic is not very helpful.
You have to remove the back panel on the bottom. Use compress air to blow out all the dust inside. (wear a dust mask).
Jan 30, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Philips projection tv
Sep 09, 2008 | Philips Magnavox 9P6034C 60" Rear...
Orange projection lamp on. Picture is a bluish green, no true white.
If you are in warranty contact Lg electronics since they own Zenith. I was having similar difficulties and they are sending me a replacement tv even though I am out of warranty by 3 years.
Jun 09, 2008 | Zenith D52WLCD 52" Rear Projection...
Panasonic T.V...
What is your tuner source? Cable,Satellite, antenna?...accordianman
Nov 13, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba 42HM66 42" Projection HDTV Logo
119 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
