Question about Motorola Mobility L6 Cellular Phone
I have turned off the sound somehow and so it will ring and all but the key tones wont play and music wont play with out head phones and texts with sound wont play with out head phones
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
  • Press the Navigation key.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
How to turn phone on and off-sonyericsson C902, also how to change ring tones
1. Use the call disconnect key to switch ON & OFF your cell phone.
2. To change you ring tones, Select MENU, then SETTINGS, then you will be seeing the GENERAL tab. use the navigation keys to move across the tabs and select SOUND & ALERT. Then Select RINGTONE and you can select your music you needed.
Jun 10, 2010 | Sony Ericsson Cyber-shot C902 Cellular...
My ring tones have stopped working on my Blackbery
There may be a setting that got adjusted somehow. Go into your Options (the wrench icon) and select "Sounds and Ringtones." Under "Ring Tone," there is a volume setting -- make sure it is not set to "Silent." Underneath that, there is a setting called "Play sound" -- make sure that's set to "Always"or "Out of holster."
Do other sounds work on your BlackBerry (such as music files, video clips, or alerts)?
Jun 01, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Double ring tone issue
Go to the same place that you go to to put it on vibrate and scroll down to set ring tones/alerts and sms text and change the settings the volume should be set to silent.
Apr 20, 2010 | RIM BlackBerry? Tour 9630 Smartphone
My phone doesn't ring.
has it gotten wet? have you tried restarting it and taking out the battery? It could just be a faulty phone if that didn't work and it hasn't been wet. you can get it replaced most likely
Sep 21, 2009 | Pantech Matrix Cell Phone
The phone doesn't ring, there is no speaker phone, and no tones when you dial or text.
Try using the side keys to adjust the volume. It sounds like the phone is on silent. Go into the audio settings and play around the ring tone, text, dial tone sounds and settings until you feel that it is appropriate for you.
If the phone is still not responding with sounds or tones after you have set the audio settings, the phone might be defective and you may need to have the phone company look at it.
- Neal
Apr 27, 2009 | AT&T LG CU515 Cell Phone - Black
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Can i make a song a ring tone on the g1 phone
download the free app ringdroid in the app market.connect g1 to computer and mount .drag music into music folder.then open rigdroid.the music you dragged into folder should be here.cut the waveform however you want then save. now you can go to settings and under sound and display you can assign your newly made ring tone to your default tone.
Nov 30, 2008 | HTC G1
Doesn't ring at all
My phone wont play music it ceeps saying unsupported file it is
a samsung sgh-x830
Aug 13, 2008 | Samsung SGH-E900 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
