Question about HP Pavilion dv6000z Notebook
Laptop not detecting hard drive or cd drive
Its a hp zv5445usand it worked fine for the longest time now it wont detect dvd or hdd drive and the drives work fine (tested in another laptop) any ideas?
  • think_alien Nov 14, 2009
    theres no os cause hard drive not working so no drivers and connectors checked and checked again
  • 81 Answers
Check the connectors of the two devices and the drivers.
Posted on Nov 14, 2009
Just replaced my hdd on Compac Presario 2100 but the system is not detecting it.
This model laptop came with a 60Gb hard disk and if you installed a much larger capacity hard disk then the BIOS cannot detect this hard disk.
For the BIOS to detect a large hard disk a BIOS upgrade is required (if there is one available) Check the HP/Compaq WEB site to see if there is a BIOS upgrade.
If not the try a 120Gb or smaller capacity hard drive.
As an alternative -
You can keep the existing hard drive in your laptop and use an external USB hard drive to store your data.
Nov 10, 2012 | HP Compaq Presario 2100 Laptop
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
My acer aspire one has a hard drive failure on the following disks IDE/SATA.I diagnosed it then got the following report. HDD doesn't respond to system commands Boot sector damaged read time...
You need to format your hard disk. Please note that formatting will erase all you data from the hard disk and all the software including the Operating system.
If you have your OS master CD you can insert it in the cd/dvd drive and restart the laptop. This will detect the OS CD and try to install it. In the installation process there is an option "Format your hard drive". You should select that option. Then it will format, mark the bad sectors, create a new boot sector and install the OS. You will be just fine.
Aug 03, 2011 | Acer Aspire One PC Notebook
Have a WD2500BEVE on WIN XP SP3, laptop HP nx6125. Works very well, but control light for HDD on laptop permanently lighting. It lights wenn no action on HDD is on too. Lights permanently - no flushing as...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working hope this helps
Jun 17, 2011 | Western Digital WD2500BEVE Hard Drive
In my compaq v3000 other 120gb hdd detection is ok but when i connect wd1200bevs then their is no hdd detect in cmos setup, hdd works very fine on usb hdd connector.
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 20, 2011 | Western Digital Scorpio WD1200BEVS 120 GB...
How to install windows XP on my toshiba satellite A40, my bios not detect others device like my external dvd portable, cause everytime i instal with cd rom on my notebook always show 'blue screen error' or...
I'm not familiar with that specific model, but if you install from cd and get blue screens and the hard drive is not always detected, this means the hard drive is failing. You will have the same problem if you do manage to get the external cd/dvd drive to detect.
If the A40 is new enough to use a SATA hard drive (I do not think it is) then you need an XP cd with SP2 or 3 included or you will get bluescreens. But the fact that you can't get other OS to install make this an unlikely suspect.
The cd drive could be bad and not copying all the files correctly, but since you say the hard drive sometimes will not detect makes it almost certain that the hdd is the main issue.
Mar 15, 2010 | Computers & Internet
RE-INSTALLATION PROBLEM
it doesn't seem to be cpu. have you tried to update bios? download usb bootable latest version of your bios and give it a shoot. if it does not help, try use external cd drive to reinstall os. press f9 at startup and choose usb hard drive. oh, one more thing-this may be memory corrupt, but not likely. test it in the bios.
Sep 09, 2009 | HP Compaq 6735s Notebook
Trying to locate a HDD caddy/Connector
In normal circumstances it would be a USB 2.0 but I don't know what you are connecting it to.
Jul 29, 2009 | Computers & Internet
Problem in cd-dvd drive of hp laptop
This is not a driver problem. It is almost certainly a problem with yourdvd/cd player. If it is reading dvd's, then it means that the driver is installed. You will have to take your laptop in and possibly get the cd/dvd player replaced.
Dec 09, 2008 | HP RT865UTABA - HP Promo dc5700 micro...
HARD DRIVE is not detected
Hi
Yes, problem with hdd you need to buy new hdd, no other choose....
Thanks
May 02, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv6000z Notebook Logo
61 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
